Hi there. I am new to XS1100s although I had a 650 Midnight Maxim back in the mid 80's. I had a 1985 Shadow 1100 for 14 years, and an '82 750 Virago now.
I just bought a 1980 XS1100 that sat for a few years. When we first looked at it, it started easily and idled just a little rough. It had a bit of smoke out the pipes, that looked more brownish than blue, so I assumed it was from sitting.
Well, as I drove it home it started to smoke (blue) worse and wrose until the bike lost power and I had to pull over. It wouldn't start, so we loaded it in the truck and took it home.
At home it started no problem with the battery charger to help.
I filled it up with fresh gas, and set about doing a minor tune-up. New plugs, adjust the cam tension, checked compression, put some diesel on top the pistons, to free up any stuck rings (after).
Compression was 145, 55, 75, 155, which is why the diesel to free up rings, hopefully.
While I was adjusting the cam tensioner, my nephew walked by and hit the starter, briefly, and I had the key on....
The motor turned maybe 1/4 rev and stopped. The cam chain had slipped several teeth...
I have been trying to realign the cams, I set the timing mark on F/T (tried C too) and set the little dots on the cams to the arrows on the brng cap.
The bike will not start. It spits out the exhaust and the carbs, but will not start...
Is it possible to get the timing out 180deg, like a car, or should it be bang on if all the marks line up? What's the chances I now have bent valves?
Thanks for any help you may have!
