Drilling the baffles
  • werleje
    • Jul 2005
    • 5
    I have searched the posts about removing the baffles. Found some interesting stuff. Unfortunatly i haven't been able to find any instructions on where exactly i should drill them out. If anyone could point me in the right direction it would be appreciated. I have an 80xs1100sg.
    Hey Werleje,
    I believe we are mostly talking about the large flat flange end that the baffles are mounted into. We drill holes in the end plate AROUND the baffle, not necessarily directly into the baffle tube itself! Hope this helps!
    • werleje
      • Jul 2005
      • 5
      Thanks for the info, thats what i was thinking, just wanted to make sure before I started drilling, i was thinking 4 3/4" hole evenly spaced in the plate should work.
        You might want to try smaller holes first, and then test the sound. That way you can "tune" it by increasing the hole sizes without necessarily going too big too soon! Just a suggestion!
        • xj11john
          • Jun 2005
          • 440
          • Lafayette, TN
          When I had my 4-1 exhaust I drilled 4 1/4" holes and it made it quit a bit louder and lower toned. I would definetly start small and try it first as T.C. said.
          Heres a pic of mine after drilling.
          '82 Xj1100j
          "Ride for the Son"
          John
          • werleje
            • Jul 2005
            • 5
            Thanks for all the info guys, I'll definitly start with the smaller holes and go from there.
            • posthuman
              • Aug 2006
              • 71
              So I tryed this...
              drilled 3 1/4 inch holes per baffle
              sounds stupid like a golf cart now
              hhuwwAaAaAaA
              wierd hollow phazey sound
              I'll put sheet metal screws back in the holes and paint them black
              XJ 1100
              XJ 550
                • 7831
                On the stock 78, I drilled 4 1/4" holes, 90 degrees apart, on the flat end plate of each muffler. The sound was just a little louder, and I had a little more at the top end.
                Ray
                • Fredjohny
                  • 74
                  • Gibsons, BC Canada
                  Hello,
                  I am at 4 - 5/8ths holes per muffler, that size got rid of the tiny sound
                  82 XJ1100 Maxim
                  80 XS1100 engine and parts doner
                  Awsome machine.....love going on rides.....
                  black on black
