Carb Hoses ... Where
  • 79XS11F
    • Jul 2006
    • 3563
    • Ottawa, Ont. Canada
    Allrighty then .. My pod air filters arrived today and I am installing them.
    Question ... The 2 vent hoses off the carbs that used to go to the air box, what do I do with them? I am guessing they must remain open? The crank case vent hose that also used to go to the air box, what happens with it? Should I drill a neat tidy hole in the end of one of the middle pod end plates and attach it there or dose it just need to have a filter added to its end.
    It's going to be a tight fit for my Dial-A-Jet system so I will be calling them tomorrow to see if they can be mounted at the ends of the pods with their feed tubes facing straight at the carb mouths. If so I will have to do some trickery to mount them.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
  • John
    • 5117
    The carb vent tubes can be routed up under the tank, and using a T or Y fitting, place a small filter on the ends to allow breathing, and keep varmits out. The crankcase vent tube can be routed down behind the engine, but put a filter in it also.
    • 79XS11F
      • Jul 2006
      • 3563
      Will gas fumes not escape from the vent hoses? If so would there be enough fumes to stink up a 11 x 17 garage?
      Rob
      1978 XS500E
      1981 Suzuki GS1100
        • 7640
        Rob,
        with a filter on the end of the tube, you should NOT smell any gas. I would use a paper fuel filter on the end, as you can see if it all of a sudden is getting wet!
        Ray
        • 79XS11F
          • Jul 2006
          • 3563
          Thanks for the info Ray. That's what I will do then.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
