Brief history
The bike had been running reasonably well but seemed to lack pulling power in the mid throttle range and had a misfire at constant throttle settings and a rough misfire idle. Mostly when warming up.
Last Thursday (July 27) I removed the baffle of my MAC 4 into 1 pipe and packed the outside of the baffle to control noise and possible poor exhaust resonance because the stop plate has been removed from the baffle. I used the bike the balance of that day for a few short trips. there was no change to the above condition it was just less noisy.
I parked the bike that Thursday evening to remove and return the front wheel for a defective tire issue.
Got the tire issue issue sorted and reinstalled on Wednesday (Aug 2) and went for a test drive. The bike was misfiring and had a REAL rough idle but seems OK after a short 5 KM run.
The folowing Thursday morning (one week since being parked)when I went to go to work the bike again had a very rough idle and the bike ran so poorly that I did not take it to work. As we know from the other thread (Timing pickup question) the ignition would appear to be working correctly.
So today is re & re the carbs day to reinstall all the jetting that came with the bike. The jets have been soaking in carb cleaner all night.
While I have the carbs off I will check all rubber seals and blow out all passage ways again.
While I am doing this job I will from time to time take a break and check here for any input that can be offered as to what's going on with this bike.
Rob
Rob
