Pod Air Filters
  • 79XS11F
    • Jul 2006
    • 3563
    • Ottawa, Ont. Canada
    WOW I just took it for a test Run and it is worst now and the plugs were black as black can be, How the hell Can a engine with STOCK jetting be running RICH after putting on a 4 into 1 header and pod filters. It's beyond me I'll tell you. I owned a 78 model in 1980 and with one main jet size bigger and one down on the needle the bike ran VERY VERY well. This thing is a mystery to me so I will at this point LEAN out the mid range by LOWERING the needle 1 position over stock.
    Unreal
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • 50gary
      • Apr 2006
      • 225
      • Saginaw, Michigan. USA Third stone from the sun
      Question, are you plugs wet black or dry black?
      Cheers, 50gary
      • 79XS11F
        • Jul 2006
        • 3563
        Cheers, 50gary
        Dry black .. Very black
        Rob
        1978 XS500E
        1981 Suzuki GS1100
        • 79XS11F
          • Jul 2006
          • 3563
          #34
          OK I pulled the carbs and dropped the needles 1 notch and test drove the bike. The issue with the bogging out or serious stumbling is now at about 5500 RPM so a Minor improvement. It also behaves the same if a crank the throttle as well. So I don't want to drop the needle any further so I'm not sure where to go next. I need the #45 pilot jet for a smooth idle but perhaps I can dial it down further
          Any other ideas guys
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • 79XS11F
            • Jul 2006
            • 3563
            #35
            THE HELL with POD filters for now
            OK .. I just went for a ride with my drilled AIR BOX back on the bike and the dial-A-Jet set in the middle position. Needle jet is still in the lean position . WELL ... my entire mid range had been found and the bike goes like snot!!! I have smooth idle, STRONG midrange and good top end. I think I will save myself some cash for the time being and leave well enough alone.
            Rob
            1978 XS500E
            1981 Suzuki GS1100
