right side sparkplug keeps fouling out????
  • ninjazg
    • 7
    • IL
    hello guys and gals new to the forum,got a question,the right side spark plug keeps fouling out notice some power lost and sputtering put another plug in and its fine until it happens again...Any suggestions??? thanks:
    have fun worry later...
    • 5061
    Re: right side sparkplug keeps fouling out????
    Maybe the fuel valve (aka float valve) is leaking, or the carbs need synched, or you are using the choke too long, or the pilot screw in No 4 needs screwed in a tad....
    • prometheus578
      XS-XJ Super Guru (RESIGNED)
      • Aug 2004
      • 4012
      • Olympia , Wa.
      "Hey Sparky!"
      Could be electrical(weak or intermittant spark to #4. Bad wire or plug cap), but most likely, as Skids mentioned, is carb related.
      Float needle not seating, float set incorrectlty, pilot screw setting... hell, the main jet might have fallen off and is lying in the bottom of the bowl!
      Either way, the carbs should be removed fer a look-see.
