Clutch Cable Length
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    Clutch Cable Length
    What is the clutch cable length in inches on our bikes. I found a ggod deal on true S.S. Braided, I don't have an extra one to measure at this time....thanks again
    MDRNF
    79F.....Not Stock
    Hey Chop,
    A spare cable I had measured 55 inches, I think it was for a Standard, the Special might be a little longer due to pull back bars?!
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      thanks t.c.
      I am going to purchase one off ebay for a v-star custom...the ends match, and I will keep you posted...thanks again...chop
      MDRNF
      79F.....Not Stock
      • Lamric
        XStremely XSive(Deceased)
        • 410
        • Kenley, Surrey, England
        Standard cable is 53.5 inches from end to end, outer Sleeve length 49.5 inches.
        Brian
        XS1100 LG "Mr T", SG "ICBM" & FJ1200
        Check out the XS Part Number Finder
        Be not stingy in what costs nothing as courtesy, counsel and countenance.
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          thank u-2
          well, I was figuring t.c. gave me the length of a special..I have low handlebars and ordered the "custom" SS Braided cable from a v-star...I will keep posted....thanks again
          MDRNF
          79F.....Not Stock
            Hey Chop,
            My concern is not the overall length, but the length of the exposed section of cable that fits down into the clutch engine cover, is it the same for the V-star vs. the XS11?? That's where it looks like it might cause a problem with fitting??
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              length
              Yeah T.C., that was my only concern too. So I measured the "Relaxed" distance on a spare cover i have and I determined the donor (v-star cable) has to be at least 2.25". I will get the cable tomorrow and install it. If the length is a little longer. I will make a spacer between cable and clutch cover... I will make it work one way or another. The Sportster Throttle cable had to be cut down a bit near the twist, other than that, a perfect fit....chop....p.s. i found 3 of them at 30 ea...real s.s. braid
              MDRNF
              79F.....Not Stock
