I've got a tapping on the top end of my motor and would like to have it fixed. Anyone know wnyone in northern Ohio who can be trusted?
Someone to work on my bike
No one in Northern Ohio, but I know a guy that is central ohio that is good. He only works on old Japanese bikes. Let me know and I'll give you his number78E ... Gone but not forgotten
2006 Kawasaki Concours....just getting to know it -
Tap TAp, not a knock???
First adjust the cam chain, (very easy to do) check tech tips
If still there and it is in the top end may need valves adjusted.
Still not hard to do, but will take a few hours. (gotta clean off the old valve cover gasket if it needs to be replaced
If still there then you may need a m/c tech.
mro
btw
just checking the valve clearance is easy to do, just need a "feeler gage", other than one alen wrench and 19mm wrench. Info in tech tips too.Comment
Breyley Yamaha in North Royalton has done some work for me in the past. Not cheap but they've got 2 old timers that know the XS11 very well. If you are close to Cleveland, PM me with contact info and maybe if put our heads together we can figure it out.
Mark Stanton
78XS11eComment
