Signaling for help
    Well,
    All I can tell you then is that I used the 2 prong electro-mechanical flasher from Trico found in auto store, and it's worked perfectly with my LEDs.
    • 81xsproject
      • 3185
      • Fortuna, CA
      thanXS anyway, TC. I really think that I screwed up the ones I have by trying them in so many wrong configurations. I might try that type you are talking about.
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • 81xsproject
        • 3185
        • Fortuna, CA
        Still F-ing with this thing
        So, I went out and spent another $13 for this...
        I tried it on the bike and then tested it like this and tried switching the wires going to the flasher...
        it still wont blink!!!!! I just don't understand what the hell I could be missing. TC, do you have any regular bulbs in your system that could create a load? I plugged the same flasher in on my buddies KZ that has regular bulbs and it worked great. I am to the point that I am considering putting some regular bulbs inline somewhere to create a load. But that defeats the whole purpose of converting to LEDs (other than visibility).
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
        • audijunky
          • Apr 2006
          • 707
          • VA
          I am not sure that 1 led bulb will create enough load to make that flasher relay work. I also have used this relay but with regular bulbs. Just disregard the connection going to the cancellation relay and connect the flasher relay to the bike. If both signals and the indicator on the cluster light but dont blink, you know its the relay. If not then it may be wiring. Just make sure you disregard the correct wire. I tried a three prong(+ - and L) using the cancellation unit in every cofiguration possible and couldn't get it to work. You may also want to check for continuity between gound(frame) and the return(-) from the LED or relay depending on how you wire it.
          79 XS1100 modified standard
          straight pipe 4-2 exhaust
          Owned 83 Honda V65 Magna
          Owned 02 Vstar 650 classic
          owned 85 Honda Shadow VT 700C
          • planedick
            • Mar 2005
            • 2068
            • Yorba Linda, California
            Wrong side...
            The power (+) side is the one that is to go through the flasher, no?
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            Custom security system
            Stainless braid brake lines
              Yes, Dick and Jessie,
              The power lead goes to the flasher FIRST, and then thru the light, and then to ground! My turn signals are all LED, but my indicators are still regular bulbs, but like Dick said, the power goes to the flasher first, the bulbs are downstream from the flasher/power!
              • 81xsproject
                • 3185
                • Fortuna, CA
                DOOO!! I drew it wrong. ThanXS for the error report. Yes, I set it with pos to flash, flash to light, light to neg.
                '81 XS1100 SH
                Sep. 12th 2015
                RIP
                • LoserShoes
                  • Apr 2005
                  • 524
                  • Bangor Maine
                  From the looks of your picture, that thing has a relay in it, is going to require enough load current to operate the relay. It's really electro-mechanical, not electronic. You need something that uses a transistor to turn the lights on and off. Will probably have a seperate gnd terminal to power the electronics.
                  Steve
                  73 Yamaha DT3 - DirtyHairy
                  CZ 400 MX'er
                  68 Ducati Scrambler
                  RC Planes and Helis
                    So Steve,
                    What you're saying is that I guess with all of the wiring on my bike(Resistance), and the load of the turn signal indicator on the bars, combined with the 2 LEDs 0.3amp draw each, that's why Mine works with that Electromechanical flasher, but Jessie's won't with just his single LED circuit??
                    Jessie, I'm sure you can offer that Trident one to a member for resale, even me cause I'll be rebuilding 2 bikes and I'm sure the flashers won't work on at least one of them, not to mention I'll be adding LEDs to them as well, so I'll take it off your hands, shoot me a PM with your PayPal addy!!
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      So you do have some regular signal indicator lights? Unless you really want the flasher TC, don't worry about it. I appreciate the offer but I can always use it on my buddies kz or something.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
                        Jessie,
                        Both of my signal lights are LED's, only the dash/control console turn indicators are standard bulbs, those little 194 style, only draw 7watts, about 0.5 amps, but that may be enough combined with the .3amps for each LED on one side to activate the flasher!?!?
                        • 81xsproject
                          • 3185
                          • Fortuna, CA
                          Maybe, cuz I have LED's in the dash too.
                          '81 XS1100 SH
                          Sep. 12th 2015
                          RIP
                          • LoserShoes
                            • Apr 2005
                            • 524
                            • Bangor Maine
                            Yep, thats probably just enough!
                            Steve
                            CZ 400 MX'er
                            68 Ducati Scrambler
                            RC Planes and Helis
                            • xschop
                              • Feb 2006
                              • 1794
                              • oklahoma city
                              true Electronic
                              you need a true ic type flasher
                              MDRNF
                              79F.....Not Stock
                              • 81xsproject
                                • 3185
                                • Fortuna, CA
                                got any recommendations chop?
                                '81 XS1100 SH
                                Sep. 12th 2015
                                RIP
