another #%$%&&&$??bolt question
  • another #%$%&&&$??bolt question
    Does anyone know for sure the correct thread size for the rear wheel axle? I don't have an extra one lying around to measure it either....thanks ....chop
    MDRNF
    79F.....Not Stock
    Hey Chop,
    According to my micrometer, it's about 17.75mm diameter which should make it an 18mm. It has a 1.5mm thread pitch.
    I have some 20mm x 1.5mmpitch threaded rod, and it's about 19.75mm diam!
    The castle nut for it is the same as for the XS650:
    650 90171-18008-00 NUT, CASTLE (256-25382-00)
    XS11 90171-18008-00 NUT, CASTLE (256-25382-00)
    Regrettably, the Yamaha site didn't state the actual size!?
    Hope this helps!
      thank you t.c.
      did you use a thread pitch scale? I am getting some titanium castle nuts ordered and wanted to be sure....thanks again...chop
      MDRNF
      79F.....Not Stock
        Hey Chop,
        I took my 1.5mm pitch threaded rod and held it next to the spare axle I had, and the threads meshed perfectly! I know my threaded rod is 1.5mm, it's the same pitch as the oil filter bolt, I had to determine that in finding suitable threaded rod to make the supply tubes for my S.O.F.A.s, so I'm very sure that the axle is the exact same pitch.
          muchos gracias
          thanks(english). I am getting a front and rear nut in titanium, believe it or not, it is cheaper than trying to get the stainless ones, and they polish out just about the same....thanks again
          MDRNF
          79F.....Not Stock
