I put a new clutch cable on and it's really tight. The tension bolt at the lever end is all the way in providing as much "slack" as possible. It's so tight that after an hour in rush hour i can barely pull it in to shift. Can the arm connecting the cable to the clutch be shifted to allow more slack?
PS. granted the cable could probably use some lube, but i really don't think that's the problem. There's no slack when applying the lever and the lever springs back really hard with a good WHACK.
