SHOCK STUD SIZE & leaking oil from head gaskets
  • RVERHEECK
    • 4
    what is the stud size on the shock mount on the 1100 and how hard is it to fix a oil leak on the head gaskets?
    The rear shocks use a 10mm X 1.25 nut, IIRC. The head gasket hardly ever leaks oil, but the valve cover gasket will. If you need to check the valve lash, just pick up a new gasket and the "half moon" seals. Once the new parts are on, you should not have a leak. If it look like it's leaking from the front of the engin, it's probably the cam chain adjuster that is leaking.
    You can search the "Tech Tips" on the left, and do a search of the threads to find most of the answers you will need.
    Ray
