2nd Gear Prevention
  • MAXIMAN
    • Jan 2005
    • 1817
    • As far from the government as humanly possible.
    2nd Gear Prevention
    Any of you XSives ever given thought to techniques or maintenance that might prevent the ominous 2nd gear failure.
    Obviously shift technique is crucial. But I've talked to some guys that swear they babied their Eleven only to have 2nd gear eventualy go out anyway.
    Then again I've talked to guys that have 80 or 90,000 miles and never had a problem.
    Any thoughts...any superior oils that might help?
  • pggg
    • 1609
    • NZ
    The guys that babied their elevens could have previous owners thrashing the hell out of them? Slick-50 or Motor-Up would be good in the gearbox if it wasn't for the wet clutch.
      • 7640
      I would pull the trans, and do the "washer move" on 2nd. That will probably get you an extra 70K miles without a problem. The best way would be to go in and do the trans completely. Slight undercut, washer move, and adjust and verify all shifting BEFORE you put everything back together.
      Just my $0.02.
      Ray
      • mason79
        • Mar 2006
        • 1351
        • los angeles, ca
        thats the most milelage anyone can get with a single washer, at the rate i'm riding, that will be another 14 years, year 2020.
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • MAXIMAN
          • Jan 2005
          • 1817
          Not me. I put about 25,000 to 30,000 annually on bikes.
          Regardless I know a couple guys that have well over 70,000 original miles with no tranny problems. One put 90,000 on an XJ and never had any gear issues.
          Still....if I can "help" the situation I would be diligent to do so. Sounds like the best thing I can do is simply cross my fingers.
            • 7640
            That, and go easy until 3rd gear!!
            Ray
            • yamarider
              • Jun 2006
              • 52
              • Pueblo, Colorado
              As far as I know, this second gear issue was with the '85 Venture Royals. Does it carry over to other four cylinder models as well??
              Yamaha Believer
              Jack of all trades - Master of none
              79 XS1100, Macho Maroon
              80 XS1100, came and gone
              80 XS650 Special, friends for years
              86 XV1100, putt-around-town bike
              • Don Hughes
                • 61
                • Edmonton, Alberta Canada
                Was a problem with the 83 to midway through 85's when Yamaha fixed the problem on the Ventures.
                Some where I even have the serial # that they fixed it at in 1985.
                Do not know about other Yamaha 4 cylinder bikes.
                Don Hughes
                Ex-1978 E
                Ex-1985 Yamaha Venture Royale
                1991 Yamaha Venture Royale
                1990 Honda Goldwing
                Edmonton
                • Pat Kelly
                  • 3046
                  • Golden Valley, AZ
                  Some of the XS triples have 2nd gear issues too.
                  Pat Kelly
                  <p-lkelly@sbcglobal.net>
                  1978 XS1100E (The Force)
                  1980 XS1100LG (The Dark Side)
                  1999 Suburban (The Ship)
                  1994 Dodge Spirit (Son #1)
                  1968 F100 (Valentine)
                    • 7640
                    The second gear problem started with the XS1100, and went on through the Venture and the vmax. Too much tourque.
                    Ray
                    • mro
                      • Oct 2005
                      • 4276
                      • Hayward, California
                      If it ain't broke , don't fix it
                      mro
                      • GNEPIG
                        • Apr 2005
                        • 1647
                        • fl
                        .. i'm not going to mess with the red bikes tranny any more, it's working real good now, but i'm going to try something a little different/easier with the next bike[XS11 tranny]. the long winded explination that i posted previously requires you to take the transmission out, but this time i'm only going to remove the clutch to get to the washer based bolt. i am going to try just putting a .065" thick washer under the washer based bolt. this will move the drive axle over about .040", this also moves the second gear wheel closer to fifth gear wheel. this should give the second gear about .035" more dog engagement..
                        ..this should in up being a quick and easy improvement towards helping 2nd last longer
                        • yamarider
                          • Jun 2006
                          • 52
                          • Pueblo, Colorado
                          I wonder if this second gear issue is brought upon by personal shifting habits? When I am cruising through town and come upon a stop, I never downshift into first -- the XS has plenty of torque to start out in second gear, even with a passenger. Maybe this whole second gear problem arises from the repeated "jump" between first and second gear.
                          Yamaha Believer
                          • pggg
                            • 1609
                            • NZ
                            GNE, got me interested, reckon it's possible that way?
                              • 5051
                              You should donate your first gear!
