What's next?!
  • Radiation
    • Jun 2006
    • 90
    • Eugene, Oregon
    What's next?!
    I finally got the bike running, so I got up this morning and spent 2 hours reinstalling the d*** airbox so I could start dialing it in. Got everything put back on and when I turned the key on, there was nothing. I am not getting any juice. I checked the new battery, plenty of juice. So I have spent the last 6 hours going through all the connections, checking the fuse box and anything else I can think of.
    If anybody has any ideas, I would greatly appreciate.
    This bike does NOT want me to ride her!!!
    Bill
    1980 XS 1100 Special
    1979 650 Special - sold (Stupid Me!)
  • gerkenbruce
    • 392
    • Upstate NY
    Been there
    HI Radiation
    I worked a longtime once to find out that my killswitch was on .
    In behind your fuses ther is some wires you may have pulled a part behind the air box one littel from the starter botton.
    XSively
    Bruce
    Bruce Gerken
    '79 XS1100SF
    "The Black"
    '2009 BMW k1300GT'
    The Red Sled.
    St.Augustine (354-430 AD) wrote,"The world is a book and those who do not travel read only a page . Well motorcycles turn the book of the world into a page turner. That is often impossible to put down.
    • Dragonrider
      • 1219
      • Garland, Texas
      Did you check the MAIN fuse? It's not in the fuse box...it's a rubber thingy in the wire under the LEFT side cover (or sometimes pushed up to just under the seat on the left side.
      CUAgain,
      Daniel Meyer
      Author. Adventurer. Electrician.
      Find out why...It's About the Ride.
      • Ljay40
        • Jun 2006
        • 149
        Yup thats what was a matter with mine 2
        • Radiation
          • Jun 2006
          • 90
          • Eugene, Oregon
          you the man!!
          You called it Dragonrider. I opened the main fuse and I must of broke it while I was fighting with that **** airbox! Put in the spare and she lit up and I fired it up. SWEET!
          Bill
          • Dragonrider
            • 1219
            • Garland, Texas
            Cool!
            When I changed the fusebox for a blade fuse one, I also relocated the main fuse in there.
            CUAgain,
            Daniel Meyer
            • Radiation
              • Jun 2006
              • 90
              • Eugene, Oregon
              sounds good!
              I just ordered 2 of those blade fuse blocks from Topcat. I think I will do the same. Do you know if there is a reason why they have the main fuse clear on the other side of the bike?
              Bill
                Hey Bill,
                The Main Fuse is a higher rated 30AMP, the wire tap from the battery cable is also bigger, and I "GUESS" allows less distance of that wire putting it separately from the other fuses, vs. routing it to the fuseblock and then back up to the main switch!?
                I would think you might just get a separate SINGLE fuse holder at Walmart or such to replace the main one with, so as not to have to mess too much with that LARGER gauge wire!?
                I do recommend running the AUX terminal THRU the new block, though!
                • Radiation
                  • Jun 2006
                  • 90
                  • Eugene, Oregon
                  That makes sense. That's why I say things here before I actually do it. You guys keep me from making first timers mistakes.
                  Thanks.
                  Bill
