Bread tie syncronization
  • CUBuffs
    • 252
    • Castle Rock, Co
    I just tried the bread-tie sync on my carbs and also readjusted the idle screws. After syncronizing I set the main adjustment screw back to where it was (I had counted the number of revolutions after marking the postion). The idle screws were seated and then backed out about 1.5 turns.
    Now the bike doesn't idle nearly as well as it used to and without the choke open idles around 800 rpm. Would I be correct in thinking that is related to the idle screws and not the carb sync?
    80 XS11 SG
    79 XS750 SF
    74 KZ400
    78 KZ650
    78 KZ750
  • CUBuffs
    • 252
    • Castle Rock, Co
    Adjusted idle mixture screws
    I just opened up the idle mixture screws to what I believe to be a full 3 turns. It seems to idle a little bit better.
    Should I be adjusting the main idle adjustment screw instead?
    80 XS11 SG
    79 XS750 SF
    74 KZ400
    78 KZ650
    78 KZ750
    • CUBuffs
      • 252
      • Castle Rock, Co
      Main idle adjustment screw
      I opened up the idle mixture screw to 3.5 turns with no noticeable effect so then I increased the idle on the main idle screw and got it to idle at around 1100 rpm. Seems to be ok now, I'll have to check the plugs later.
      I'm still open for suggestions.
      80 XS11 SG
      79 XS750 SF
      74 KZ400
      78 KZ650
      78 KZ750
      • GNEPIG
        • Apr 2005
        • 1657
        • fl
        .. looks to me like your doing quite well on your own, we look forward to taking suggestions from you very soon...
        • CUBuffs
          • 252
          • Castle Rock, Co
          Thanks Gnepig
          80 XS11 SG
          79 XS750 SF
          74 KZ400
          78 KZ650
          78 KZ750
          • mro
            • Oct 2005
            • 4276
            • Hayward, California
            Is very good to get the carbs close so it will idle good enough to allow adjusting when running.
            If you have not sync'ed the carbs w/merc stick or vac gauges you will be pleasantly surprised how much better it will run.
            mro
