which breaks more often clutch or throttle cable?
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    hello , i just change my clutch cable as a safety measure and the old one was stretched and felt gummed up even though i lubed it previously.
    flanders, $15.10, anyways it pulls great and shifts fast as heck, i didn't know that the cable had so much to do with the shifting experience...glad i did it
    i would like to do the same with the throttle cable, my question is if anyone would help is do they construct the cables to render the same cycles before failure?
    as the throttle has much less tension to go against than the clutch pack, should i just inspect and not bother with the change any comments would be apprieciated
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    Lube and go!
    I've never replaced my THROTTLE cable, have had mine since 83!
    You essentially answered your own question there!
    • JWSanders
      • 879
      • White House, TN
      I'd just remove the carb end of the throttle cable and see how freely it travels. It should be really easy to move then. If the ends check out (no frays or anything) then lube 'er up and ride!
      Never hurts to have a spare though.
      80 XS1100SG
      81 XS400SH
      Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
      A Few Animations I've Made
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        thanks guys, my initial mechanical experiece with the xs1100 was about the carbs, i was up close and personal with that cable, moves well and lubed, i'll go with it
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • webbcraft2150
          • Sep 2002
          • 1605
          • AUSTIN.TX
          I have yet to replace a cable on my 80g pushing 65k. I bought a cable luber years ago when I was into desert racing. Its a nifty device that clamps to the end of the cable and you can shoot a lube thru it. As a normal matter of maintenance, I will use it about every 3-4 months. You can also shoot carb or brake cleaner thru it to clean the cable out and then lube it. As a side note, my old Norton had a giant appetite for clutch cables, I always kept one taped to the existing one, could change that thing out in about 5 minutes. Dam thing always seemed to break at an interesection.
          • mason79
            • Mar 2006
            • 1359
            • los angeles, ca
            so is that the 2 chamber 357 mag revolver? what was it you or the cable or the xsive spring pressure it needed to overcome?
            how about the xs's clutch cable any probs?
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
            • John
              • 5117
              I have had to replace 3-4 clutch cables to only one throttle cable in the 14 years of riding my bike. It seems the clutch cale has some ware from the clutch perch, because that is where mine has always broken. The throttle cable was changed as a preventitive measure last year when I rebuilt the bike after the accident, so I have never had one break.
              • mason79
                • Mar 2006
                • 1359
                • los angeles, ca
                you think lathering that perch area with grease would help?
                History
                85 Yamaha FJ 1100
                79 yamaha xs1100f
                03 honda cbr 600 f4
                91 yamaha fzr 600
                84 yamaha fj 1100
                82 yamaha seca 750
                87 yamaha fazer
                86 yamaha maxim x
                82 yamaha vision
                78 yamaha rd 400
                • John
                  • 5117
                  I don't know about grease, but I have used WD 40 and PBlaster on that area.
                  Maybe some dry graphite lube would work well.
