fireing order????
  • Okoldschool
    • May 2006
    • 25
    • OKC, OK
    fireing order????
    what the firing order for these things? in other words which coil fires which 2 cyls and which plug goes to each cyl? the reason i ask is i have the Dyna coils which are not numbered and i have to remove my motor to change the starter clutch and i dont know which ones go where lol
  • John
    • 5117
    Firing order
    One coil will fire #1 & 4, and the other fires #2 & 3. The gray wire to the coils fires the #2 & 3 coil, and the orange wire fires #1 & 4 coil.
      You're FIRED!
      Well,
      Believe it or not, I've not ever seen the firing order listed in a manual, however, it should be 1-3-4-2 or 1-2-4-3.
      The Left side (as you ride it) fires 1-4 cylinders, and the right coil fires 2-3. Left should be Orange wire, Right Gray.
      • John
        • 5117
        Hey TC!
        Did you move my post already?
          Yeah, John,
          Right after I replied, I saw your reply in a NEW THREAD, and figured you OOPsed, so I merged it while I was there!
          I'm quick alright, sometimes too quick, at least that's what SWMBO says!
          • John
            • 5117
            Wanna go short time, Joe?
            • Okoldschool
              • May 2006
              • 25
              • OKC, OK
              Re: You're FIRED!
              Well,
              ok that tells me which coil is which but which wire on the coils goes to which cylender?
              • prometheus578
                XS-XJ Super Guru (RESIGNED)
                • Aug 2004
                • 4012
                • Olympia , Wa.
                Oh, to be young and stationed overseas again! How I hate retirement! ($10 short time, $20 overnight)
                Anyway...
                Doesn't matter. Four cylinders/two coils. Works on the wasted/lost spark method. When the left coil fires, it sends spark to cylinders #1 and #4 at the same time. Cylinder #1 will fire because that's the stroke it's on. Cylinder #4 gets the same spark, but is on the exhaust stroke, the spark is ineffective and is wasted. Much cheaper design than having a seperate coil fer each cylinder.
                As fer which wire goes to which cylinder... each coil usually has one wire longer than the other. For the left coil, the short wire goes to #1, and the longer wire crosses over the valve cover and reaches #4.
                • LoserShoes
                  • Apr 2005
                  • 524
                  • Bangor Maine
                  Ok, so which is cylinder 1? Left or right?
                  I realize it's implied in your answer, but sometimes things have to made really clear.
                  Steve
                  80 XS1100G Standard - YammerHammer
                  73 Yamaha DT3 - DirtyHairy
                  62 Norton Atlas - AgileFragile (Dunstalled) waiting reassembly
                  Norton Electra - future restore
                  CZ 400 MX'er
                  68 Ducati Scrambler
                  RC Planes and Helis
                  • mpcluever
                    • Feb 2006
                    • 52
                    • Minneapolis Area in MN
                    everything is numbered left to right as you see it while sitting on it.
                    1981 XS 1100 SH
                    • John
                      • 5117
                      You'd be suprised at how many non mechanical people don't know which side of a car/bike is which.
                      • Okoldschool
                        • May 2006
                        • 25
                        • OKC, OK
                        Maybe im not saying it right. My question is Which coil goes on the left and which one goes ont he right? And since my coils are dyna coils and have removeible wires which post on the coils are which? IE the left coil has what coolor of wire and which terminal on it goes to cyl 1 and which one goes to cyl 4? and vise versa for the right side coil.
                          • 7830
                          The coil fires BOTH wires at the same time. It does NOT matter what wire goes to what side, as long as the two wires on the left coil go to the two OUTSIDE plugs, and the two wires from the right coil go to the two INSIDE plugs.
                          Ray
                          • Okoldschool
                            • May 2006
                            • 25
                            • OKC, OK
                            ok cool thanx guys. i hate not knowing anything about bikes. lol
