Help - broken throttle cable 300 miles from home :(
  • mixelpix
    • Sep 2004
    • 237
    • Utah
    Hey All,
    Does anyone know where I can get a replacement throttle cable for an 1980 XS1100LG in Los Angeles?
    Well, it pays to listen to that inner voice... I have a new one at home in Oakland, CA - but that won't help me in L.A. Alas.
    I am supposed to be back to work on Wednesday and the soonest the nearest Yamaha dealer said they could get one delivered by is Tuesday morning. Now, while a quick tank lift, and throttle cable replacement plus a jaunt up the I-5 might sound like a fun way to spend a Tuesday day, afternoon and evening... I am still barely able to ride. Fortunately the throttle snapped just below the pivot point inside the handle and I am able to wrap the throttle cable arm (the L shaped fitting which guyides the cable into the handle) around my palm and goose the cable to give throttle, but it's not exactly ...ideal.
    Any help would be greatly appreciated. In fact, if anyone has one I'd be happy to paypal you or send you a check or money order if you could overnight it to me.
    Thanks!!!
    -Patrick Kennedy
    Your Mileage May Vary
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    theres
    hollywood yamaha
    pasdena yamaha gets things over night you just have to pick it up
    bert's mega mall
    i have a 79 standard if it fits i'll give you mine, it's not running now that i'm waiting for a part, just pay me for a new one...
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
      Just a thought but there has got to be some motorcycle graveyards around. Have you tried some of the salvage yards. Might just be the fastest way to get a cable. If you do just make sure you give an ample does of lubricant.
      • mixelpix
        • Sep 2004
        • 237
        • Utah
        Thanks!!
        Originally posted by mason79
        theres
        hollywood yamaha
        bert's mega mall
        Hi, thanks so much for the quick response. I might just take you up on your offer! Everyone is closed right now or can't get the part 'til tuesday.
        XS1100F
        2H7-26311-01-00 WIRE, THROTTLE (91 OMM)
        XS1100LG
        3H3-26311-00-00 CABLE, THROTTLE 1
        The part numbers are close enough that I sure would be willing to give it a try. How far are you from Culver City?
        thanks again!
        -Patrick Kennedy
        • mixelpix
          • Sep 2004
          • 237
          • Utah
          Thanks for the suggestion! Off to search for salvage yards...
          -pdk
          • mason79
            • Mar 2006
            • 1359
            • los angeles, ca
            Re: Thanks!!
            XS1100F
            XS1100LG
            thanks again!
            -Patrick Kennedy
            i'm near pasadena,
            405n
            10e
            past downtown
            atlantic off north to alhambra
            go 3 miles
            20 or so miles
            unfortuantely i will miss the solvang ride, with a little luck and timing you can make it though
            310.666.6622 cell
            mason wang
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
            • mixelpix
              • Sep 2004
              • 237
              • Utah
              Thanks so much - I'll give you a ring shortly.
              Also, just wanted to give another shout out to Dan of DansMC fame:
              ALL ABOUT BOWDEN CABLES (even a reference to Flanders - so smart this guy!)
                I know that some shops will make them up for you...
                • prometheus578
                  XS-XJ Super Guru (RESIGNED)
                  • Aug 2004
                  • 4012
                  • Olympia , Wa.
                  What Skids said! Bring your old cable and bits to a good shop ( best bet might be an independant shop), and have them quickly build one fer yea. They usually have spools of cable... and just solder your ends and stuff to it.
                  • pggg
                    • 1609
                    • NZ
                    If the shops are closed it won't matter as it's only 300 miles to ride. I tie string to the cable and run it to my throttle hand at the bars.
                    • turbopete
                      • Jun 2005
                      • 120
                      • Kent, U.K.
                      Mine snapped away from home on the XJ. It had broke in the twistgrip. I cut back the outer cable about an inch, then crimped part of the cut-oof bit to the inner with a pair of pliers and jammed it in the twistgrip hole. Got me home no problem.
                      • mason79
                        • Mar 2006
                        • 1359
                        • los angeles, ca
                        i'm thinin how about just tying a big fat knot or to... and stick it back in..
                        History
                        85 Yamaha FJ 1100
                        79 yamaha xs1100f
                        03 honda cbr 600 f4
                        91 yamaha fzr 600
                        84 yamaha fj 1100
                        82 yamaha seca 750
                        87 yamaha fazer
                        86 yamaha maxim x
                        82 yamaha vision
                        78 yamaha rd 400
                        • mixelpix
                          • Sep 2004
                          • 237
                          • Utah
                          thanks everyone!
                          she's back on the road
