Has anyone tried Yamaha's fuel tank rust remover? I just discovered it on the following link.
Yamaha fuel tank rust remover
I used to use it when I worked in a Yamaha dealership 20 odd years ago. It works very well.
I think there are other solutions now that are easier to come by.
The old gray biker ain't what he used to be. -
johnsons
look into johnsons tank liner. I have my tanks done with this and is the best route from my experience. This is the liner after the treatment of HPO3. I have posted before that citric acid will clean your tank rust without destroying any new metal. the phosphoric acid (HPO3) sacrifices some of the surface metal to make the new iron phosphate coating. So the question at hand is if you have a light rusted tank or heavily rusted tank....chopMDRNF
79F.....Not Stock
80G......Not Stock Either....In the worksComment
FYI
If anyone is interested I tried the Yamaha rust remover. So far it seems to work. Just one word of caution, make certain that you have no leaks through the petcock holes or fuel sender hole before you add the rust remover to your tank.80 XS11 SG
79 XS750 SF
74 KZ400
78 KZ650
78 KZ750Comment
