How about some cam timing?
  • How about some cam timing?
    I liked the thread by 81xsProject about his 79 cams in the 80 XS. My question is this. Has anyone tried tinkering around with cam timing to place the torque/power curve in your most favorite riding range?
    I understand that moving the intake and exhaust cams in relation to each other will have an effect but I am not sure what that would be.
    Also, does anyone know if a set of cam sprokets are made with slotted holes that will work on the XS?
    Mike Giroir
    79 XS-1100 Special
    Read the last few post of this thread:
    Dyno results hot off the press!
    It shows a dyno run after my cams were dialed up. It pushed the torque curve down into the 3000-6000 range.
    Their are no available pre-slotted sprockets. My dealer slotted the stock sprockets with his mill and dialed them in for me. It worked.
      I am considering slotting a set of cam gears. Should I be concerned about the cam gear slipping?
      DZ
      Vyger, 'F'
      "The Special", 'SF'
      '08 FJR1300
        Thanks for the input
        Maximan, thanks for the link. Very interesting and it has my thirst for tinkering rising. I think I am going to have to try it out but I dont have access to a dyno. Guess I will have to use the seat of the pants method (fun fun fun).
        Denny, A couple of my friends dragrace bikes and they use slotted cam sprokets without any worry about movement. But then, thats only 1/4 mile at a time. Still, I do not think there would be any 'unplanned' cam adjustment with slotted sprokets. but I suspect that checking cam timing would become a routine maintenance item.
        Mike Giroir
        79 XS-1100 Special
          Thanks TADracer for the info. I will proceed with the cam slotting. I a m concerned about slipping, I could always whip an insert to put in the slot.
          The cam sprockets are made of some tough stuff, milling slot will be interesting. To date, I have only milled aluminum.
          Once I get the program setup, send me your sprockets!
          DZ
          Vyger, 'F'
          "The Special", 'SF'
          '08 FJR1300
            You can also drill the hole oversize and use an eccentric bushing.
            Steve
            80 XS1100G Standard - YammerHammer
            73 Yamaha DT3 - DirtyHairy
            62 Norton Atlas - AgileFragile (Dunstalled) waiting reassembly
            Norton Electra - future restore
            CZ 400 MX'er
            68 Ducati Scrambler
            RC Planes and Helis
