How about some cam timing?
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    I liked the thread by 81xsProject about his 79 cams in the 80 XS. My question is this. Has anyone tried tinkering around with cam timing to place the torque/power curve in your most favorite riding range?
    I understand that moving the intake and exhaust cams in relation to each other will have an effect but I am not sure what that would be.
    Also, does anyone know if a set of cam sprokets are made with slotted holes that will work on the XS?
    Mike Giroir
    79 XS-1100 Special
  • MAXIMAN
    • Jan 2005
    • 1817
    Read the last few post of this thread:
    Dyno results hot off the press!
    It shows a dyno run after my cams were dialed up. It pushed the torque curve down into the 3000-6000 range.
    Their are no available pre-slotted sprockets. My dealer slotted the stock sprockets with his mill and dialed them in for me. It worked.
    • Dennyz
      • 1151
      • Olympia, Washington
      I am considering slotting a set of cam gears. Should I be concerned about the cam gear slipping?
      DZ
      Vyger, 'F'
      "The Special", 'SF'
      '08 FJR1300
      • TADracer
        • 1417
        Thanks for the input
        Maximan, thanks for the link. Very interesting and it has my thirst for tinkering rising. I think I am going to have to try it out but I dont have access to a dyno. Guess I will have to use the seat of the pants method (fun fun fun).
        Denny, A couple of my friends dragrace bikes and they use slotted cam sprokets without any worry about movement. But then, thats only 1/4 mile at a time. Still, I do not think there would be any 'unplanned' cam adjustment with slotted sprokets. but I suspect that checking cam timing would become a routine maintenance item.
        Mike Giroir
        79 XS-1100 Special
        • Dennyz
          • 1151
          Thanks TADracer for the info. I will proceed with the cam slotting. I a m concerned about slipping, I could always whip an insert to put in the slot.
          The cam sprockets are made of some tough stuff, milling slot will be interesting. To date, I have only milled aluminum.
          Once I get the program setup, send me your sprockets!
          DZ
          Vyger, 'F'
          "The Special", 'SF'
          '08 FJR1300
          • LoserShoes
            • Apr 2005
            • 524
            • Bangor Maine
            You can also drill the hole oversize and use an eccentric bushing.
            Steve
            73 Yamaha DT3 - DirtyHairy
            CZ 400 MX'er
            68 Ducati Scrambler
            RC Planes and Helis
