Thanks for the advice guys. I pulled the cam chain tensioner just to be sure it was working properly and all checks out.
Then I did what TopCatGr58 suggested and pulled the plugs while running. The instant I pull the plug cap from cylinder 2 the knocking stops. So I guess you guys are probably right that there is a bad rod.
TopCatGr58, what are the differences between the parts you listed. I see that same list on bike bandit but I don't know what the significance of the colors are. Which parts will I most likely need? The new bearing and a new rod. Anything else?
Thanks again guys. You are being very helpful.
I had the jugs slightly slanted, and I had the 2-3 piston set up, and inserted 2 first. The bottom of the jugs had a nice taper cut into them, so along with oiling the pistons, rings, and the jugs real well, I just compressed the rings, and slide the jugs down onto the piston, 2 and 3, then was able to slide them down onto 1 and 4, again, having the jugs slightly slanted enabled me to work with 1 cylinder at a time....ALL BY MYSELF! Not bragging, just wanted to offer another possible approach!
