xj 1100 engine stall
  • 633wrench
    • 13
    • edmonton ab
    i hope someone can help,i have a 83maxim 1100
    when i put the bike into gear it snuffs out engine
    i have just pulled out the middle gear to rebuild it
    bearings were toast does someone have an answer
    to this problem?
    thx
    • 7830
    You have a sidestand safety switch on your bike. It's the problem.(95%)
    Take a look at the wires around the middle drive unit. If you have one that has been pinched, that may be it.
    Ray
    • 633wrench
      • 13
      • edmonton ab
      checked for pinched wires everything checks out,is there another way to test? could it be clutch related?
      thx
        • 7830
        I would use a VOM to check the wires. The manual with a wire diagram helps. If I remember, you can unplug the wire off the switch, put a little tape over it, and then try again. If it goes in gear, then the switch is bad.
        If you think you can get by without, ask John...
        Ray
          Hey!
          I resemble that remark!
          Actually the XJ side stand switch is known to fail. Unplug it and use an ohm meter to test it with the stand up and down.
          • 633wrench
            • 13
            • edmonton ab
            kickstand switch
            hey!
            thanks,to all who replied switch was stuck!
            now all is good went for first ride on this bike
            whooo hooo!
            633wrench
