RC Performance Products and Mikuni VM Roundslide Carburetors
+ More Options
Posts
  • Harleychanic
    • Jan 2006
    • 25
    • Mullica Hill, NJ
    I just picked up a complete engine today with a set of Mikuni VM33A 14 roundslide carburetors and a RC Performance header and exhaust system. I was wondering if anyone has ever heard of this company and if so, could they point me in the right direction to get some information on their products. Also the engine starts with 3H3-....... what year motor is this, it has the kickstart shaft so I am assuming that is a 79? One more thing, does anyone have any info on the Mikuni roundslide carburetors as far as tuning them?
    I can't help much with the carbs or pipes, but I can tell you that tha 3H3 engine is from a 79 Special.
    • Harleychanic
      • Jan 2006
      • 25
      • Mullica Hill, NJ
      Thanks John, I figure that this is the best place to ask the questions!
      • Dennyz
        • 1151
        • Olympia, Washington
        Mikuni VM33
        Go to Google and search on "Mikuni VM33".
        I ran a set of these on my 'F' for a short while. They are kind of an "OFF/ON" type of carb. Great for drag racing, not so great for touring. Uner 2000 RPM they are very flat. Above that, "Great Ball of Fire"! It was not easy to hold a steady RPM.
        The ones I used required dual throttle cables (pull open/pull closed) which mean I could not used the stock throttle housing.
        I tried to sell the set on eBay a few of years ago for $100 with cables and throttle. Now body was interested.
        DZ
        Vyger, 'F'
        "The Special", 'SF'
        '08 FJR1300
        • lparker
          • 20
          • sebring florida
          rc was russ collins big in perf parts in 70s made a real good product exh and cams and other go fast parts dont think there around any more the pipes were as good or better then kirker
          • oldbiker648
            • Jul 2003
            • 182
            • Richmond, VA
            DZ,
            Do you think the pull on-pull off feature is a safety item that eliminates the need for a throttle return spring, yet gives you a positive way to cut off the throttle? It does sound like those carbs are more of a racing proposition than a cruising item. Do you remember what type of mileage you got when you had them on the bike?
            Have you thought about trying to sell them to Bandet in Ohio? He's bound and determined to crack into the 12's this year at the drag strip, might be willing to make the carb switch.
            _________________
            John
            78E
            79 SF (2)
            80 G "The Beast"
            81 H "The Dresser"
            79 XS650 II
            82 650 Maxim
            70 DT-1 Enduro
            66 Honda CL-77 Scrambler
            96 H-D Road King
            "The road to hell is paved with good intentions."
            • Dennyz
              • 1151
              I never checked the mileage with them. I don't see how they would improve mileage over the stock carbs.
              I still have the carbs if somebody is interested (PM me).
              DZ
              Vyger, 'F'
              "The Special", 'SF'
              '08 FJR1300
              • oldbiker648
                • Jul 2003
                • 182
                • Richmond, VA
                Denny,
                Check with Bandet, he's looking for some help to get into the 12's at the drag strip this year.
                _________________
                John
                78E
                79 SF (2)
                80 G "The Beast"
                81 H "The Dresser"
                79 XS650 II
                82 650 Maxim
                70 DT-1 Enduro
                96 H-D Road King
                • Harleychanic
                  • Jan 2006
                  • 25
                  • Mullica Hill, NJ
                  The set of carbs I that I got have a very large, very strong return spring on them. It takes a good bit of force to get the slides to rise so I doubt that you would need the push pull throttle for them. The PO that I got the engine from recalls that after the 2k the bike would pull like a "freight train"! I think that I will be putting either the 1179 or 1196 kit in the motor along with 2nd gear fix as my winter project and then possibly stuf it into my 78 or find another donor that needs a good engine!!!
