dimple in tank
  • Jby1999
    • May 2006
    • 21
    • PA
    dimple in tank
    I just got my xj1100j 2 weeks ago let someone sit on it and i turned my head it dropped. Scuffed the windshield by the left turn signal and the handlebar put a quarter sized dimple in the top back of the tank near your inner left thigh. The dimple is only 1/16 - 1/8 deep. Any ways of getting this looking normal again it bugs me everytime i goto sit on it.
    LESSON LEARNED:
    NO ONE SITS ON BIKE WITHOUT ME ON IT!
    XJ1100 Maroon
  • bikey2003
    • 7
    Go to the local auto parts store and buy a valve lapping stick. They have a suction cup on both ends each a different size. Wet the largest suction cup that will fit , plop it onto the dent, and pull! Just might work...Terry
    • dewibp
      • Jun 2005
      • 315
      • Work out of Dakota Dunes SD but live in eastern Iowa (Quad Cities)
      If fix #1 does not work go to a paintless dent repair company. It worked for me.
      DEW
      One Red "Creation 1"
      One Black"Creation 2"
      One Black"Creation 3"
      One ???? "Creation 4"
      One ???? "Creation 5"
      One ???? "Parts Bike"
      All the above 1100 Specials
      78 Standard (Ruf Ruf)
      1980 Midnight Special
      1978 650 SE
      • Jby1999
        • May 2006
        • 21
        • PA
        how much can i look to spend on a paint less dent repair. my tank has some scratches just wanna wait till i am comfortable with it b4 i dump money into chrome and paint! and what might the paint code be for the 82 xj1100 with the marron color
        XJ1100 Maroon
        • JWSanders
          • 879
          • White House, TN
          Dragonrider has a nifty method described here
          80 XS1100SG
          81 XS400SH
          Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
          A Few Animations I've Made
            • 7712
            jby,
            Paintless dent repair company uses "spoons" to push the dents out without needing to repaint. It may cost a lot, for the job. You may also be able to take in the bike, and a car with one or two small dents, and get a package deal.
            It IS a good way to go, and then it's done already, so you just paint when you are ready.
            Ray
            • dewibp
              • Jun 2005
              • 315
              Really depends on the size/number of dents. Like Ray says "more dents/cheaper price".
              DEW
              1978 650 SE
              • Pat Kelly
                • 3046
                • Golden Valley, AZ
                I used a "Pops-a-Dent" (as seen on TV, infomertials) on several dents in my tank and Suburban. Worked quite well.
                Pat Kelly
                <p-lkelly@sbcglobal.net>
                1978 XS1100E (The Force)
                1980 XS1100LG (The Dark Side)
                1999 Suburban (The Ship)
                1994 Dodge Spirit (Son #1)
                1968 F100 (Valentine)
                • TADracer
                  • May 2006
                  • 1417
                  • Kenner, Louisiana USA
                  Had a small dent in the side of my special tank thanks to our neighbor's daughter. I took the tank from the bike and drained it then held the tank cap tightly shut and applied air into the tank through one of the petcocks. Used low pressure first then gradually raised the pressure with the regulator until the dent just popped out.
                  Mike Giroir
                  79 XS-1100 Special
                  • pathfinder
                    XStremely XSive(Deceased)
                    • Apr 2004
                    • 483
                    • Houston, TX
                    A bit airish
                    Watch your pressure, I sealed the petcock holes and the filler hole put air into it thru a petcock screw hole. I blew that tank so big it probably would have held 8 gallons. Except for the fact it was ruined I guess it was OK. It only took two seconds and a new tank fixed it right up.
                    There's always a way, figure it out.
                    78XS11E
                      • 5058
                      Re: A bit airish
                      You too, eh? Very spooky when it jumps off of the frame!
                      • pathfinder
                        • Apr 2004
                        • 483
                        • Houston, TX
                        Re: Re: A bit airish
                        Sorry, but glad I wasn't the only one.
                        78XS11E
                        • osmosis4b
                          • Apr 2006
                          • 75
                          • Winters, CA
                          I have heard a piece of dry ice rubbed over the dent on a hot day will do the trick, never seen it though
                          79' XS1100SF "Eleven Special" - Black/Gold
                          -all original
                          87' 750 Virago "Hardley" conversion
                          - dual tanks
                          - full dress... minus fairing
                          - chopped exhaust
