If I only want to check compression on one cylinder do I need to remove all the plugs or just the one I plan to test?
Checking comp on one cylinder
Engine warm. (2-3 minutes at idle.)
Fully charged battery.
Throttle wide open.
All spark plugs removed.
You COULD leave the other spark plugs in and check it.... it just wouldn't be right!!
*Crashed/Totalled, still own -
While you can leave the other plugs in, it's not recomended
The starter will be under more load, so won't turn as fast which may mean a lower reading (and a hot starter)
If your head gasket is leaking between the cylinder you're testing and one with a plug still in it, its pressure could be different than what is its true reading
David
Of course an expert can come along and shoot down my years of ingrained myth
Please do
XS1100G (3X1 000274) "Torquey"
You can think of a lightning bolt as essentially a really really big bug zapper. Unfortunatey, we're the bugs.Comment
