should i rebuild the brake calipers?
  • Yamaniac
    • Jul 2005
    • 262
    • Stilwell, KS
    you may not need a rebuild kit, Mason. I had good luck with just getting them apart, cleaning all the metal parts in carb cleaner, Triple washing them (with dish soap) to make sure you get all the residue off. wash all rubber parts with dish soap and water. DOT3 used when assembling. Has worked great for me.
    Yamaniac
    '79 xs11 sf - WidowMaker, 750 final drive
    '80 xs1100 sg- ENEMY#1 parts bike no title(free)
    '79 f- frame and swingarm (and title)
    '82 yz 490- needs a cylinder, head, & new piston, etc. Got one for sale?
    '88 Honda cbr600- Running, finally! Training bike for swmbo, maybe a stunt bike for me eventually.
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      but is it that the rubber is close to 30 years old and may desintergrate soon?
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        I've never seen that. The only probs I've seen concern the rubber components exposed to air, such as the dust boots on the outside of the calipers and master cylinder. Gets hard and brittle, etc.
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          thanks prom i'll be patient and split the work into 2 days, one to remove inspect and the other to replace as nessessary? or to play it safe go for the new stuff what's your opinion?
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
          • GNEPIG
            • Apr 2005
            • 1657
            • fl
            .. i have never had to replace the oring in any of the calipers i have taken apart and if you pick your oring out of the groove nicely you wont have to either. dont clean the oring with brake cleaner or other hard chemicals, the rubber will expand then you will have to replace it, i like the soapy water idea. i have made a scraper out of a piece of coat hanger to clean the groove out with. just smash one end flat with a hammer and bend it your own special way to get it in the hole and start scraping the groove. if your brakes were hanging up/stuck/binding then you should get a lot of oxidation out from under the oring
            .. hope this helps
            • mason79
              • Mar 2006
              • 1359
              • los angeles, ca
              .. hope this helps
              this whole place helps and i'm thankful
              History
              85 Yamaha FJ 1100
              79 yamaha xs1100f
              03 honda cbr 600 f4
              91 yamaha fzr 600
              84 yamaha fj 1100
              82 yamaha seca 750
              87 yamaha fazer
              86 yamaha maxim x
              82 yamaha vision
              78 yamaha rd 400
              • prometheus578
                • Aug 2004
                • 4012
                • Olympia , Wa.
                "with this ring... I thee bled."
                (Ok... concerns bleeding the system, not rebuilding... but it's 4:00AM and I'm tired)
                Clean the large O ring with brake fluid and scrape the white crap off with your thumb nail. GNEPIG's right on with the coat hanger. Use a VERY fine sandpaper to smooth the caliper bore and the sides of the piston. It's a very close fit, but should slide in and out smoothly. (If it doesn't do it now... it won't do it later, either)
                • mason79
                  • Mar 2006
                  • 1359
                  • los angeles, ca
                  how fine, should i put a hone like a cylinder? what grit?
                  bte, where should i dump the brake fluid with my old oil?
                  decsions, decsions...
                  History
                  85 Yamaha FJ 1100
                  79 yamaha xs1100f
                  03 honda cbr 600 f4
                  91 yamaha fzr 600
                  84 yamaha fj 1100
                  82 yamaha seca 750
                  87 yamaha fazer
                  86 yamaha maxim x
                  82 yamaha vision
                  78 yamaha rd 400
                  • Ken Talbot
                    • 4251
                    • Revelstoke, BC
                    I wouldn't use a hone. Stick with 600 grit or finer sandpaper wrapped around your fingers.
                    Ken Talbot
                    • Yamaniac
                      • Jul 2005
                      • 262
                      • Stilwell, KS
                      it may be too gentle, but I use 00 steel wool and wd40. Someone else on here recommended that. It will clean things up, and you'd have to use it for a long time before you went too far with the honing.
                      an angled pick and WD40 worked great to clean out the oring groove for me. Just be careful not to score the walls
                      Yamaniac
                      • prometheus578
                        • Aug 2004
                        • 4012
                        • Olympia , Wa.
                        "Honing your mechanical skills"
                        Ken's got it right
                        One only needs to do this if there's visible corrosion on the cylinder walls.
                        From what the company that picks up our used oil tells me, brake fluid can be mixed in with oil. some autoparts stores have a container for customers to dump off their used oil, or check out the recycling/hazardous waste area of the local landfill, etc.
                        After the caliper's clean, move the piston in and out a few times(before putting the o ring back in), to make sure it slides smoothly.
                        • mason79
                          • Mar 2006
                          • 1359
                          • los angeles, ca
                          lemme see if i got this right
                          recycle dot 3 with oil
                          groove will be dirty, scrape with flattened hanger or pick
                          look for corrosion, if yes lightly sand with 600 or finer or 00steel wool and w d, ( i like w d)
                          no rebuild kit required
                          should i tear down the m c before i go out and get a kit?
                          History
                          85 Yamaha FJ 1100
                          79 yamaha xs1100f
                          03 honda cbr 600 f4
                          91 yamaha fzr 600
                          84 yamaha fj 1100
                          82 yamaha seca 750
                          87 yamaha fazer
                          86 yamaha maxim x
                          82 yamaha vision
                          78 yamaha rd 400
                            • 7844
                            Mason,
                            I would have a rebuild kit for the MC BEFORE I started. That way, you can remove, clean, and replace WITHOUT forgetting what part went in the hole first.
                            Ray
                            • randy
                              • Dec 2003
                              • 4521
                              Mason,
                              Ditto what Diverray said.
                              Oh, and I would never use steel wool on aluminum parts. Steel fibers get imbedded and then rust.
                              • wingnut
                                • Oct 2005
                                • 695
                                • NC
                                Scrubbing Pad
                                What Randy said. Do not use steel wool on aluminum. Go into the chief cook and bottle washer’s kitchen and relocate a one of those scrubbing pads or head down to the auto parts store and ask the guy for a scotch bright pad. I think you will find them in the auto body section. That and the WD 40 and you should be able to clean it all up. You can even use the scrubbing pad in the o-ring grove to get rid of the white stuff
                                wingnut
                                81 SH (Daily Ride)
                                81 XS 400
                                Thomas Jefferson
