should i rebuild the brake calipers?
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    i have some ss lines ordered for the front of my f, and was wondering if anyone knows, if i clean out the m/c real well and bleed the system, will there be sludge left in the brake calipers?
    is there a low spot/place where the sludge may settle in the calipers?
    i'm trying to avoid rebuilding them as they don't leak or stick, and there is no rust.
    i think the m/c could use a good cleaning though, and the old lines will be a thing of the past.
    this will save a little money and a bunch of time, you can call me a lazy xs owner
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • wingnut
    • 695
    • NC
    Slduge
    Mason when I was working on my brakes I thought I had flushed the calipers out really well with brake clean and compressed air then with DOT 3. I put it all back together and one of them hung up so it had to be rebuilt. When I got it apart there was still sludge in the caliper even after the pints of brake fluid and cleaner I’d pumped thru it. If you want them clean inside take them apart. I reused the seals and boots on one and the worked great. Just clean them up with brake clean or DOT 3. Do not use petroleum based cleaners. It dose not react well with brake fluid. Makes more sludge.
    wingnut
    81 SH (Daily Ride)
    81 XS 400
    Thomas Jefferson
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      okay, i gotta do the whole thing...
      at least i'll stop, cause it ain't stoppin.
      can you explain how the pistons come out? and is it easy? thanks wingnut!!
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
        Yes, there will still be sludge in the calipers behind the pistons. Easiest way I've come across to get the pistons out is with a shot of compressed air from a rubber-tipped air nozzle. Put a heavily folded up rag between the piston and the other side of the caliper and keep your fingers well out of the way. Leave the bleeder in place, apply the tip of the nozzle to the hole the banjop bolt came out of, and give it a light shot on the trigger. Be ready to catch!
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          is there another way? cause i don't have a compressor
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
          • pathfinder
            XStremely XSive(Deceased)
            • Apr 2004
            • 483
            • Houston, TX
            mason, I rebuilt mine in my apartment parking lot years ago. Vise grips on the piston above the groove that the dust boot fits in. Use the M/C to pump them out as much as possible. It takes awhile and does mar up the piston, but in an area that has no sealing surface. The square o-ring on the piston can most likely be saved by cleaning well with dot 3. I know I'm going to start something here, but I have been running dot 5 for years with no ill effects. I like dot 5 because you could wash the bike with it and not screw up the paint. Dot 3 make's a mess out of a good paint job.
            78XS11E
              Without a compressor, try the air hose at a gas station. Get a tubeless valve stem and press the rubber end against the banjo hole. Press the air chuck to the filler end of the valve stem and pop - out she goes!
              • prometheus578
                XS-XJ Super Guru (RESIGNED)
                • Aug 2004
                • 4012
                • Olympia , Wa.
                Like Pathfinder stated, use the master cylinder to pump the piston out. Take the pads off first and keep the master topped off. (Keep the cover on the master cylinder when squeezing the lever, as brake fluid will squirt out the spooge hole and you'll paint the ceiling of your garage) Do one caliper at a time. Have a pan ready... makes a hell of a mess.
                As for the compressed air method, Ken didn't stress this point enough, so I will. "KEEP YER BLOODY FINGERS OUT OF THE WAY", or that's just what you'll end up with.
                  Brake fluid eats paint!!!
                  Originally posted by prometheus578
                  Like Pathfinder stated, use the master cylinder to pump the piston out. (SNIP)makes a hell of a mess.
                  • mason79
                    • Mar 2006
                    • 1359
                    • los angeles, ca
                    will rebuid kits from mikes650.com fit?, i think the cross reference
                    xs650efgh
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
                    • mason79
                      • Mar 2006
                      • 1359
                      • los angeles, ca
                      btw, for those constantly looking...
                      http://cgi.ebay.com/ebaymotors/ws/eB...%3AMEWA%3AIT:D
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
                      • 84xj1100
                        • Sep 2005
                        • 47
                        • Rockland Ontario Canada
                        Not that I'm an expert by any means, but I have done my own calipers with the assistance of someone with an air compressor and by myself without.
                        Quite frankly the air compressor method actually scares me a little, in that the amount of force at which I saw the piston fly out of it's housing leads me to emphasize the warnings of other responders.
                        I would also shy away from the "vise grip" method as it can really marr up the piston and in doing so open the piston up to premature oxidization (rusting).
                        That would leave my endorsement with the messy push it out with brake fluid method. Although messy (with potential paint problems) at least you have control over the "velocity" at which the piston comes out and it doesn't marr up the piston itself. One other advantage is absence of "knuckle rapping" that may occur with the other two methods.
                        As my daughter would say "good luck with that".
                        Ed
                        "ride to be visible but pretend you're invisible"
                        84xj1100
                        82xj1100
                        • knewsom
                          • Apr 2006
                          • 378
                          • San Diego, CA
                          Someone (not sure if it was Prom or Randy) suggested to use a thick scrap of leather around the piston, and THEN grab it with the vicegrips, prventing any damage to it. I'm going to be using that method (heh, I've got a bunch of armor grade leather kicking around - I'm in the SCA) myself, since I don't have a compressor. I'll post again when I've done it with results.
                          Kristoffer
                          "Take apart yer carbs!"
                          1978 XS1100E - "The Maroon Baboon" (SOLD)
                          1979 XS1100 (3 of them) in the garage. Not deserving of names yet.
                          • knewsom
                            • Apr 2006
                            • 378
                            • San Diego, CA
                            round and round she goes....
                            will it ever come out? nobody knows!
                            Actually, it did work, but was a major PITA. Just gotta be patient, keep on it, and eventually, she'll come free, and you'll be able to get at all the nasty gunk that's in there. Be prepared for a GOOD grip workout though - phew!
                            And definitely use THICK leather. I gave up at one point and stated just using the vicegrips alone on the piston, don't do that. it'll DEFINITELY score it up a bit, and doesn't work much better - not worth the risk, IMHO.
                            good luck.
                            -Kris
                            Kristoffer
                            • mason79
                              • Mar 2006
                              • 1359
                              • los angeles, ca
                              i think i'll use a big bucket elevated by a milk crate to catch the dot3...
                              dirty work but someones gotta do it, i need to stop and will not want to go into the system for a while....
                              History
                              85 Yamaha FJ 1100
                              79 yamaha xs1100f
                              03 honda cbr 600 f4
                              91 yamaha fzr 600
                              84 yamaha fj 1100
                              82 yamaha seca 750
                              87 yamaha fazer
                              86 yamaha maxim x
                              82 yamaha vision
                              78 yamaha rd 400
