Carb issues ??
  • gaffer77
    • Jul 2004
    • 444
    • gloucestershire england
    Carb issues ??
    Hi i am posting this for a friend ,this is as much as i know of his problem
    XS1100S is a european model only i think??
    Usually had black bodied carbs but his are silver so i am dubiouse as to them being for the S model and wonder if you can help with your knowledge of what any of you may know??
    Hi All
    After some advice?
    I have got a set of carbs from what I think are from an xs1100s
    I have managed to obtain new parts like the main jets, float valves and seats
    pilot jets. mixture screws with springs,flat washer,and o rings, float bowl gaskets,
    and so on, but my problem is that, shouldn't there be a blanking plug in the float chamber
    that covers the pilot jet?
    I have just been to Fowlers in Bristol and they did confirm that the carbs I've got
    are from an xs1100s, and looking at their diagrams there is no blanking plug fitted
    Is this correct? or wrong?
    Can anybody help?
    Cheers
    Paul H
    Thanx
    Gaffer
    Don't put all yer eggs into one basket ,,,case
  • randy
    • Dec 2003
    • 4521
    Gaffer,
    Easy way to tell is:
    If your pilot jet has a hair-thin orifice on the seat end, you need blanking plugs.
    If your pilot jet has a large orifice at the slotted end, no blanking plugs.
    • gaffer77
      • Jul 2004
      • 444
      Thanks Randy that makes sense (havn't delved into Carbs myself YET!!)
      Was given this info which kinda tallys up to what you say and the 2 pieces of info together makes it Crystal clear
      The 'E' and 'F' model carbs have pilot jet blanked 'cos the pilot jet gets it's fuel from the main jet.
      After that the main jet tubes changed & don't have a supply port, so the pilot gets it's supply from the float bowl, so they should NOT be plugged.
      So I reckon that means that 'Sport' carbs are OK without blanking plugs.
