kickstart options?
  • btchalice
    • Jul 2005
    • 55
    • wichita, ks
    kickstart options?
    What kickstart levers will fit an xs11? i see several on ebay for an xs 400, 650 and 850 will any of them fit without major modifications?
    im too fat to pushstart and had to jumpstart it yesterday
    79 xs1100 standard
    76 kz900 <now 1015
    Terry Meyer
  • GNEPIG
    • Apr 2005
    • 1656
    • fl
    .. i'm not sure about the 400 or the 650 but the 850 will do
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      A kick start lever will only work if your starter is bad (or you just want to kick start it). If your battery is dead or low (under about 10 volts) pushing or kicking won't work. The coils need at least 10 volts to fire so jump start is your only option in that case.
      Yes, kick start lever from the 3-cylinder XSs will work.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
        I'm pretty sure I saw a post from IIRC 650MIke, that said he had a 650 lever on his 1100, cause it folds up a bit out of the way, I think he said he did some minor mod to keep it from hitting the side cover or such, but it will fit the splines!
        There are two styles of 650 kick starter levers, straight and curved, and MikesXS sells the "rubbers" for each, but not the actual levers!
        • Geezer
          • May 2003
          • 2985
          • Willamina, Oregon 97229
          I bought a 650 kicker lever off eBay and it hit the case. It wasn't very useful for starting the engine either so I never bothered trying to fix the problem.
          I don't think the engineers that designed the XS11 ever meant for it to be kick started.
          Geezer
          • mro
            • Oct 2005
            • 4276
            • Hayward, California
            Thought he said 750
            Don't know if same as 650's
            mro
            • Pat Kelly
              • 3046
              • Golden Valley, AZ
              Adding to my earlier post about kick starting XS1100.
              I have used the kick starter on my E just to see how hard it is. It was quite easy being a 4 cylinder. My XL250 Honda would bite sometimes if you were on the wrong part of the cycle. It would occasionally kick back into your shin.
              Pat Kelly
