Main Nozzle Question
  • TADracer
    • May 2006
    • 1417
    • Kenner, Louisiana USA
    I recently went through the carbs on my 79 1100 special. The main nozzles (emulsion tubes) on the 2 & 3 carbs have a different number of holes and differnet hole pattern that those on the 1 & 2 carbs.
    Can anyone tell me why this is??
    Mike Giroir
    79 XS-1100 Special
  • Just In Case
    • Apr 2006
    • 79
    • Auckland, New Zealand
    Assuming 2 and 3 are bigger, from other threads I've read it is to make them a bit richer so they run cooler, as 2 and 3 don't get as much cooling air flow around their fins as 1 and 4. However it doesn't seem to matter as some guys here run the same jets in all their carbs. I suppose it depends on your riding style and your local air temps.
    David
    XS1100G (3X1 000274) "Torquey"
    You can think of a lightning bolt as essentially a really really big bug zapper. Unfortunatey, we're the bugs.
      It could be someone has been into the carbs, and that is one thing they did. If the bike is running well, don't worry about it. If you are rebuilding them anyway, you can make them all the same
      Ray
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        "Cool your jets, Pal" (and your engine)
        Ealy models had all the same nozzles. (the number of holes determines how much air gets mixed in with the fuel) It was later decided to use less holes in the carbs for the middle cylinders so that they would run richer, hence cooler, due to the fact, as 'Just In Case' mentioned, that the inner two cylinders don't have the same number of cooling fins as the outer two. Same reason that on some models, the inner two carbs have larger main jets.
        • prometheus578
          • Aug 2004
          • 4012
          • Olympia , Wa.
          'And further more...."
          As Diver Ray said.
          The difference in performance is so minimal, you won't notice it, anyway.
          • TADracer
            • May 2006
            • 1417
            Thanks for the input. Bike runs great so I am leaving it alone but, I suspect it came from the factory this way. I am only the second owner and I can guarantee the previous owner does not even know what a carburetor is!
            Makes sense for the two middles to run richer because of cooling.
            Mike Giroir
            79 XS-1100 Special
            • YamaRule
              • Apr 2010
              • 29
              • Nova Scotia
              just want to say thanks to the moderators for leaving this thread up. You guys just saved me alot of headache! The info on this site is awesome! keep up the good work!
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                Does anyone know if you can still buy emulsion tubes from Mikuni for our carbs?
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
                '84 Chevy K-10 "Big Blue"
