My 81 Project
  • 81XS1100-2006
    • Feb 2006
    • 105
    • Minneapolis, MN
    Changing Coils???
    No progress from the weekend, my band was playing a show.....
    But I'm pretty sure my first solution is going to be replacing BOTH coils... then I'll know. I did try my other CDI box, nothing changed, so either they both work of they're both f'd.
    Anyone know where I should look for a new set of coils??
    TO TOP CAT:
    And after taking off the headlight, all of my connections seem to be okay. Wondering how you did the wiring switch specifically?
    81 Standard "Babe the Blue"
    sticky side down!
    • lvattaboy
      • Apr 2006
      • 3
      • Las Vegas/Milwaukee
      coils
      I read your message on coils. I saw at least 2 sets on ebay over the weekend. Good Luck. tom
      Tom Attermeier
        I think TC just pulled the bottom off the switch, with the wires on, and swapped them with the old wires and bottom.
        You should look and make sure the switch will turn counter clockwise to lock. If not, plan on buying a "hd" lock system, one BIG padlock to go in the front brake disc.
        Ray
        • mro
          • 4276
          • Hayward, California
          MNS
          Hi lvattaboy
          see you have an 80LG,
          mines still in the parts gathering stage
          Post a pic, like to see how others are looking
          mro
          • 81XS1100-2006
            • Feb 2006
            • 105
            • Minneapolis, MN
            Changed the Ignition Wires...
            and.... I have running lights... hmmmm. But none of the control lights, no headlight. (this is starting to look alot like a fusing thing, maybe a fusebox rebuild is in order...)
            also, yes, the fork lock does work, I just never bother to use em, so I checked it out last night, fork lock & parking light.
            I was reading in other forums about using laquer thinner (Toluline) to soak the carbs in, going to try that in addition to the coils.
            sticky side down!
            • knewsom
              • Apr 2006
              • 378
              • San Diego, CA
              Hey man,
              I'd definitely pick up a new fuse box - not too pricy, and it generally needs to be replaced at some point (at least, so I've surmised). It sounds like the box could be the culprit after all here - I don't know what else other than bad wires could cause your control lights and headlight to not work.... unless there's simply not enough voltage to go 'round..? *shrug*
              When you pulled your carbs, how sure are you that none of the floats were leaking?
              -Kris
              Kristoffer
              "Take apart yer carbs!"
              1978 XS1100E - "The Maroon Baboon" (SOLD)
              1979 XS1100 (3 of them) in the garage. Not deserving of names yet.
              • 81XS1100-2006
                • Feb 2006
                • 105
                • Minneapolis, MN
                Unless the wiring is grounding out somewhere, I know there is plenty of juice, brand new battery, and I keep it fully charged on my charger.
                (and all the lights worked on the old batt!)
                I've heard enough to be convinced to do something about the fuze box.
                My #2 float was sticking when I had the carbs off, but was moving smooth by the time I reinstalled the carbs. That's whay I figure I'll pull'em again and soak them in toluline.
                sticky side down!
                • GNEPIG
                  • Apr 2005
                  • 1657
                  • fl
                  http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
                  .. not much time left to get this ^ mns road test
                  • 81XS1100-2006
                    • Feb 2006
                    • 105
                    • Minneapolis, MN
                    Fuse Box Info
                    ignition coils comming via e-bay. Not in any hurry with a weekend of rain comming my way.
                    I got a great bit of advice on rebuilding a fuse box, rather than replace what's there, I was told to build the fuse box inside of a little tupperware container, that way I can seal it with the lid and keep the moisture out!
                    sticky side down!
                    • 81XS1100-2006
                      • Feb 2006
                      • 105
                      • Minneapolis, MN
                      Ah-ha! got the fuses all worked out, replaces and a bit of rebuilding and all my lights work! Still waiting on the coils, but inrunning the engine a bit over the weekend, I'm still cold on #2... I guess I'm going into the carbs again.....
                      sticky side down!
                      • 81XS1100-2006
                        • Feb 2006
                        • 105
                        • Minneapolis, MN
                        New Pics
                        She's on the road, for now at least...
                        sticky side down!
                          Re: New Pics
                          Yeaaah! Now ride that bike!
                          • 81XS1100-2006
                            • Feb 2006
                            • 105
                            • Minneapolis, MN
                            Back Again.....
                            So after a couple of weeks of tooling and fussing I'm within a week (or so) of completion. I'll have the entire run of pics up for y'all here soon.
                            Recent fixes: bled & changed pads, just had the carbs rebuilt with fresh needles, tuned, & synched. About 2/3rds the way through the paint job, going from audi white to Brilliant Blue (man-o-man a pretty color, I was trying to get close to Yam-blue but ended up going just a bit lighter) Still have to final coat/wet sand before clear-coating.
                            Waiting on a rear tire, and to put in the new fusebox I just recieved from T.C. Oh yeah, there's the new speedo too (hope it works!) ....
                            After reassembly and an oil change she's soooo very close. But a very reasonable investment so far at about $1000 total.
                            There's still plenty of summer & fall riding time!!!
                            sticky side down!
                            • 81XS1100-2006
                              • Feb 2006
                              • 105
                              • Minneapolis, MN
                              Something is going right today, recieved my rear tire and my rebuilt carbs today. Methinks this is gonna be a great weekend!
                              sticky side down!
                              • 81XS1100-2006
                                • Feb 2006
                                • 105
                                • Minneapolis, MN
                                Finally It's Awesome!!!!
                                Everything has come together fantastically. Carbs on, new rear on. Cranked it this weekend and flew around. OMFG this is a fast bike. I'm in love. Here is a set of links that show the progression:
                                when I first brought her home
                                Mid teardown, ignition/bars removing hardbags
                                Reassembled, waiting for $$ to paint, tires, & carbs. But running!
                                Mid-paint (brilliant blue)
                                re-assembled and running awesome.
                                a few more things to do but mostly cosmetic....
                                Least I can do is thank this site for all it's help!
                                Cheers!
                                **I editted your photo links from URL to IMG, they should display in the message now!! T.C.**
                                sticky side down!
