are running lights stock on a 79 standard?
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    i'm waiting on a left front turn signal for my 79 standard from andreas weiss, the one i have now from ebay has 2 elements in the bulb, but only has 2 wires, not 3.
    it lights up like a running light as well as turn duties, but the rears are dark until i turn them on...
    does anyone know if stock blinkers have running lights front or rear, if not, am i experienceing a short?
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    You ain’t short, just height challenged
    My 80G has running light front, none rear.
    mro
    btw
    would have said "running lights front", but one element burned out today, but turn still works.
      Mason,
      MRO is right, the fronts are running/turn combos, but the rears are only turn, since they are ORANGE/Yellow. IF they were Red lenses, then they would be allowed to be on all the time, but Yellow are NOT!
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        thanks again gents, so far so good then,hmmm. red lights
        might as well think in terms of electrons in anticipation of the wiring job for my new fuse block, thanks for that Topcat, can't wait to get my greasy little hands on them.
        uses to be" get rid of the lights" now it's how much more can i get, hope thats not an over 40 only concern, heck it might be a safer midlife crisis...
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • prometheus578
          XS-XJ Super Guru (RESIGNED)
          • Aug 2004
          • 4012
          • Olympia , Wa.
          "You... light up my life..."
          I didn't know that.
          Run up front and turn... an' flash-your rear.
            • 7795
            Mason,
            If ypu want lights, go with LED's. You can have PLENTY of light, and not use many electrons. The electrons are few and far between on the XS1100, so the LED's are a good way to be seen. I put a pair of oval truck lamps on my vetter box, in place of the 4 round lamps. I now have a brighter headlamp at idle, and I light up EVERYTHING behind me when I put on the brakes.
            Ray
            • gnevelesx08
              • Apr 2005
              • 107
              • Whidbey Island, Washington State
              My 80G has no front running lights. The wires are there in the headlight bucket, but I currently have single wire/single element turn signals. It has Hazard Flashers in the front, the rear doesn't flash and parking lights on when handle bars are in the locked position. Whazzup wit dat?
              If I get dual element turns for the front and back with red lens for the back, then I'd be running Headlight and 2 amber up front and Tailight, 4 in the vetter trunk and 2 red turns in the rear. Okay to the question, Aren't the rear turns supposed to flash on Hazard?
              thanks
              the other brother (Dan)
              80XS1100G (Ebaybe) Whidbey Island, WA
              Lightning of 4 is better than thunder of 2.
              I always wanted a Harley. Not anymore! XS11 rules!
              • mro
                • Oct 2005
                • 4276
                AMBER Alert!!!
                Turn signals are amber, front.
                My 80G has rear amber turn/flash
                Stop/rear running light are red
                Violets are blue
                flashers are four way
                mro
                btw
                front turn/flash probably 1157 bulb
                rear 1156
                will check today as I need to replace a front one
                  News flash..Prom doesn't know everything!
                  Hey Mason,
                  Check out the tech tips, mods, electrical, you'll see info on just 1 of many ways to put LED's on!
                  Dan, yes, your rear signals should flash with the emergency flasher. IT's a separate ciruit with a separate flasher for the Emergency flashers vs. the turn signals, so you may need to do some wire chasing!?
                  Prom, always glad to provide some "Enlightenment" your way!
                  Hope this doesn't make YOU see RED?
                  • mason79
                    • Mar 2006
                    • 1359
                    • los angeles, ca
                    i vaugely read about emergency flashers, and i tore through the turn switch to chase down some failed solder joint as per diverray, and saw nothing resembling hazards, what gives?
                    another: a little off track but, what! my rear brakes operates one front caliper? i don't see the connection;literally.
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
                      • 7795
                      Mason,
                      The emergancy flashers are on the later model bikes...
                      Ray
                        • 7795
                        Mason,
                        On the rear brakes, you DO NOT have the front/rear connected. That is also later model bikes. I ride a '798 standard almost every day, and have a '78 here that I'm going to be working on. They are basicly the same bike.
                        The late '79 had the first of the tubeless rims, and the '80 went in for a lot of the other stuff.
                        Try to find the original fork caps for your bike. The '78 or '79 will fit. They have an adjustment on them that will help you with the preload on the new springs.(this is from your other thread)
                        Ray
