1979 xs1100 carb
  • roger
    • 52
    • al
    1979 xs1100 carb
    hello everyone, i need a # 1 carb for my 1979 1100, i broke the arm that holds the float pin. thanks
    • 275
    HI Roger,,,,if you cannot get a carb the tower is fixable,,,,do a seach for float pin tower fix,,,,usually drill a hole in both piece, epoxy in a small rod. A spring loaded pin pusher can save a lot of grief getting those pins out, harbor frieght,,,lube the pin, brace the tower with your finger and use the spring push pin and tower will be saved. Good luck, keep us informed, maybe others can chime in, I know its been a problem with carb work for these bikes,,,,,,,Mike in S.DIego, Pa.
    • roger
      • 52
      • al
      thanks mike, its been broke several years, it broke at the hole where the pin goes through. i drilled a hole through the tower and wired the pin on.it works good for awhile then the wire gets loose. i thought if i could find a good hull i would swap it out.
        • 1896
        Roger, I have been looking for a #1 XS1100 carb to repair your issue for several weeks. One popped up today:
        • roger
          • 52
          • al
          i seen that and just bought it. thanks for the heads up.
            • 2074
            Looks like something by the hole where the float pin goes into so be careful!
              • 1896
              Looks OK. Maybe a nick.
Name:	Z Carb 1.jpg
ID:	876181 Click image for larger version
ID:	876182 Click image for larger version
                • 1944
                If you buy replacement pins they just slide in and out loosely. They don't actually need to be press fitted because the carb bowl holds them in place anyway.
