1978 headlight
    • 7804
    Why not just buy the Truck-Lite 7" round light?
    This Trucklite headlight is $275. It ain't exactly cheap, either. It is DOT approved and proven to function well on a motorcycle. It should not blind drivers in oncoming vehicles which is also an important consideration.
    I saw this thread and it interested me. I'm just doing some digging. I'm not sure what pitfalls you might get for $50.
      • 3918
      Marty- I thought your price seemed a little high . . .
      Truck-Lite 27270C 7" Round LED Headlight Harley Hummer Jeep Wrangler CJ TJ JK NOTES: THIS LISTING IS FOR ONE GENUINE TRUCK-LITE LED LIGHT, PLEASE ADD TO YOUR CART THE APPROPRIATE NUMBER OF HEADLIGHTS FOR YOUR APPLICATION. AN H4 TO H13 ADAPTER (PART# 96630) IS REQUIRED TO ADAPT THIS HEADLIGHT TO OE CONNETION ON JEEP JK MODELS. **ONE REQUIRED PER LIGHT** JEEP JK 2007-PRESENT MODELS HAVE EXPERIENCED FLICKERING WITH THESE LIGHTS. ANTI-FLICKERING HARNESS PART #96830 CAN BE PURCHASED TO FIX THIS ISSUE. **ONE REQUIRED PER LIGHT** FOR 2014+ ELECTA TRI AND STREET GLIDES PART #5487 IS REQUIRED. SAME AS RIGID 55002 When properly mounted, exceeds FMVSS-108 and CMVSS-108 DOT requirements for low beam and high beam performance Excellent option for light, medium and heavy-duty trucks, off-road vehicles, classic cars, motorcycles and more. Metalized reflector optics provide a lighting experience that smooth and clean across the driving surface Provides a brighter, crisper and whiter light output, closer to the color temperature of daylight, dramatically improving light projection distance and overall visibility Durability and dependability of LED lighting provides a solid-state, bulb-free headlamp design that impervious to damage from shock and vibration Military grade, die-cast aluminum housing and non-yellowing, polycarbonate lens offer optimum protection against damage from impact, roadside debris and other hazards Electronics are sealed in epoxy to resist from damage caused by corrosion or moisture Advanced circuitry protects against voltage spikes up to 600v Drop-in replacement for #6014, 6015, 6016, H6024 Par 56 -- headlamp designs Uses standard, H4, 3-blade wiring connector Equipped with Truck-Lite 3-Year Limited Warranty. 1300 Lumen output per light - 2249 KURYAKYN
      $160!
      It's what the Jeep Wrangler drivers use on their Jeeps. Another brand commonly used is JW Speaker. The options are endless for the 7" round. Rectangle like mine is limited!
        • 7804
        That's a good price if it's the same light. The adaptive light posted earlier is a JW Speaker pdoduct. Revival Cycles has video reviews of some of them.
          • 3918
          Yes, it's the same brand/model:
          TRUCK-LITE 27270C 7" ROUND LED HEADLIGHT HARLEY HUMMER JEEP WRANGLER CJ TJ JK
          2 reviews
          1 product review
          $160.00
          SKU:
          27270C
          Condition:
          Weight:
          5.01 LBS
          Current Stock:
          105
          Quantity:
