Lighting on my 78 is not the best is there an option someone has discovered using LED lights?
1978 headlight
Welcome to 1978.
There are sophisticated LED options for vintage bikes and they are expensive. Your square headlight makes it more of a challenge. Some folks on here claim improvements from inexpensive options. Hopefully, you can find it with the search function.Marty (in Mississippi)
XS650E -
If you are trying cheap ones DO NOT waste money on the LED bulbs that fit the stock reflector. Get a whole LED unit that just goes in the headlight bucket. The stock reflector is not designed to be used with LED and does a terrible job reflecting it.Nathan
Theodore RooseveltComment
Yup, what Nate said.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
It's Only a low beam for $800!?!?!?Nathan
Apparently, it adapts like the LEDs on the newer FJR:
It's cheaper than $18K for a new bike with adaptive lighting.The JW Speaker adaptive headlight knows when you are leaning in for a turn and fills the void with a lumen output of 1150 (high beam) and a 750 lumen output (low beam). The more you lean the brighter it gets up to a 30 degree lean. Be aware of small and large animals around every turn so you can stay safe while rolling through nightime twisties. The JW Speaker features superior visibility (it's as bright as the law allows), improves safety, features a polycarbonate lens and is made in the U.S.A.-- Scott
♬Comment
Ducati has adaptive lighting as well. Now, you can have it on your Eleven Special.Marty (in Mississippi)
XS650EComment
XS650EComment
Seamus Ó hUrmholtaigh
Niimi Moozhwaagan
and SOXS
2008 Nomad "Deja Buick'Comment
Poprock put a LED light in his special. I'll have to text about how well it works. I know he didn't pay that much for it because he's about as cheap as I am...
It looked a lot like that 800 buck unit shown about but I'm sure he said it was reasonably priced...
TonyHi my name is Tony and I'm a bikeoholic.
The old gray biker ain't what he used to be.Comment
Why not just buy the Truck-Lite 7" round light?1979 XS1100F
