Aftermarket Gas Cap - MikesXS
    • 1249
    • Peachtree City, Georgia.
    XS11 Folks,
    Today I received my replacement gas cap from MikesXS pictured here on one of my XS11's.
    I am extremely pleased with the look and quality of this item. Although not quite the quality level of the OEM Yamaha cap (hinge area seems a little weaker), it's a great deal compared to the absolutely RIDICULOUS prices folks are asking for; used, damaged, rusty, scratched, JUNK offered on Evil-Bay.
    Since the replacement OEM seal for the Yamaha cap is $18+ from Partzilla, I figure this complete replacement cap assy. is a great deal.
    MikesXS Part #20-0034, $33.00.
    Sincerely,
    KURT
    I think Mike carries the same cap as Parts-N-More. That's where I got mine.
    I thought the quality was quite good except for the lock. I found it was pretty easy to take the lock from my OEM cap and swap it to the replacement. My key fits my tank and ignition.
      • 1249
      Greg,
      I'm going to do the same thing. I will swap this pretty cap over to my primary XS11 (The DUCK) where all the very best parts get installed. I'll move the ugly cap & the new lock/key back over to this DEAD DUCK.
      I was in a bit of a pinch in that I had three XS11's and only two gas caps so I needed an entire assembly. One of my XS11's will be needing a good bit of work from a locksmith to get it operational with a single key. vs. 3 or 4 different keys.....
      KURT
        • 2140
        Kurt:
        Thanks for the report- I've wondered if those caps were decent or not.
        I have ordered the rubber gaskets for 3 of my Specials from Mike's XS, and they are OK, but the inner circumference swells a bit and the fit becomes a bit loose and the inner lips raises up. They still work fine, just not perfect.
          • 8062
          Once the rubber gasket fails, I'm pretty sure you can fit an OEM gasket to the aftermarket cap.
