Rockwell oil cooler
  • morticiaann
    • Apr 2003
    • 90
    • Long Beach, CA
    Rockwell oil cooler
    Excellent product. I would like to put a fan on it. After bolting this on; my engine smelled better, and I sensed that I could take a longer ride without wrecking it. It screws on with no modifications.
    [IMG]http://michaelwilliamandersen.ga[/IMG]
  • morticiaann
    • Apr 2003
    • 90
    • Long Beach, CA
    Oil Cooler
    Really by Lockheed and it mounts on your horn mount with a 2"x3/4" piece of steel
    • raul
      • Sep 2003
      • 9
      • Tallinn, Estonia, Europe
      oil cooler?
      is this available somewhere or is it bolted off an aircraft :-)
      '79 sf xs11 special (stolen)
      '81 sg xs11 special (crashed, totalled)
      '82 5k7 XS 1.1 sport
      '91 moto guzzi california III 1000 (actually 950)
      '00 HD fxd super glide 88"
      '08 500 royal enfield bullet 500
      • bkr
        • Nov 2002
        • 157
        • Fredericton N.B Canada
        Oil Cooler
        Hey Morticiaann It dosen't matter what you post ,i will check it out just to watch your Red Head do her thing. Some cute. bkr
        • morticiaann
          • Apr 2003
          • 90
          • Long Beach, CA
          Oil Cooler
          I found a discussion about it at: XS11.com > Idle Talk Forum > XS11/XJ11 Discussion > Pizzas and xs oil cooler
          Mine bolted on with a Jardine 4 into 1 header. It's a tight fit.
          I happened across one at Ebay.
          HOT ROD MAGAZINE - "heat is the engine's worst enemy".
          • chevy45412001
            • Mar 2003
            • 1412
            • Jacksonville Florida
            oil cooler
            Got mine from an xs member,very pleased by the way. Anywho could not put it on yet,a few probs on my specific bike.1 the plate that the lines attach to would not fit with a kerker 4-1 header.That prob solved as two head pipes rusted through three days ago(back to stock exhaust for now). 2 on my xj there is a support bar that runs between the two down tubes right near the two hoses that run from cooler to plate.They are hard lines that connect to plate then are rubber crimped a few inches up.They will not fit in between engine and that bar previously mentioned.I'll have to notch them so lines will fit.Not a big prob at all as i am pretty mechanicaly inclined(just not a good speller though) .So in other words the actual cooler can come from anywhere,even a car trans cooler will work.THE IMPORTANT PARTS ARE THE SANDWHICH PLATE AND the BOLT to bolt the plate up. hope this helps,because i've asked many shops and mechanics about oil cooling the xj and they looked at me like i was nuts.AS USUAL THE GUYS ON THIS SITE CAME to the RESCUE AGAIN. Can't say thank you to all enough.THANKS AGAIN.sorry for the lenghty post.
            1982 XJ 1100
            • Geezer
              • May 2003
              • 2985
              • Willamina, Oregon 97229
              I have an XS850 oil cooler that I'm planning to put on the Mongrel but I have to redo the oil lines. It's plumbed for going around 3 pipes. ;o)
              Geezer
                Hey Geez! Have you installed that XS 850 oil cooler yet? I have a tip that I found very helpful. I had one of those also on my bike. I had to cut the steel lines about 1 1/2 inches from the adapter plate, and brazed some 'barbs' around the end of the tube to keep the hoses from coming off at high speed. That happened twice. Once in downtown San Diego. Luckily SWMBO had her Swiss army knife with her. What a mess.
                • Geezer
                  • May 2003
                  • 2985
                  It's still in a box in the garage. There is a place here in town that makes up SS lines, I was going to have new lines made up when I'm ready to install it.
                  Geezer
