progressive pump
  • g15usmc
    • Nov 2010
    • 365
    • 29 Palms CA
    progressive pump
    just got a new progressive no loss pump/gauge...LOVE IT!...
    Daily Driver - '04 Suzuki Marauder 1600
    Project Bike - '79 XS1100 Special
    Hi my name is Nate and I'm am Addict...I quit riding every night before bed and can't help but start riding again the next morning...
    Ride Till You Die!
    "MESS WITH THE BEST DIE LIKE THE REST" -Semper Fidelis!
    “Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
    "When in doubt, Gas it!. If it doesnt fix the problem, at least it will end the suspense!"
  • Yahman
    • Mar 2008
    • 779
    • Salem, OR
    +1 on that, they are da bomb!
    Larry
    82 XJ1100
    80 XS1100G (Project bike)
    64 Yamaha YA-6
    77 Suzuki TS-185
    • SFerinTEXAS
      • Jun 2006
      • 877
      How about a link to the scoop on this?
      79SF
      XJ11
      78E
        Guessing something like this.
        http://www.amazon.com/Progressive-Su...=pd_sbs_auto_2
        • CaptonZap
          • Jun 2010
          • 1748
          • Denver
          Originally posted by natemoen
          Or, for a little less money,
          <http://www.rei.com/product/776958/planet-bike-micromite-mini-pump>
          It doesn't have a gauge, but you carry one of those in your tool kit, doncha? CZ
          • jwhughes3
            • 2798
            • Home of the Alamo
            SKS pump
            Here is an SKS bicycle pump from Germany I picked up for $12...
            Here is one on eBay (not $12)... but there are others same concept..
            http://cgi.ebay.com/SKS-Universal-Su...ht_1239wt_1141
            One with gauge for $32...
            http://cgi.ebay.com/32-SKS-REVO-MINI...#ht_1528wt_910
            John
            '81 XS1100H - "Enterprise"
            • Yahman
              • Mar 2008
              • 779
              • Salem, OR
              The key to the pumps that we're talking about is the zero psi loss when disconnecting the pump. I'm not sure the one that John mentioned has that feature.
              Larry
              82 XJ1100
              64 Yamaha YA-6
              77 Suzuki TS-185
                I use a portable air tank for setting the air pressure on Tsunami and Purple Reign. I fill the tank to just a bit over the final pressure I want (checked with a low pressure gauge), then use the short hose that came with the tank to hit each fork air nipple. By the time you hit each nipple a couple or three times, the pressure in the tank and each fork will stabilize and be exactly the same for each one. You can do this with your regular air compressor too if you shut off the power and bleed the tank down to the pressure you want for your final. All that aside, that sure is a nice looking tool...
                • jwhughes3
                  • 2798
                  • Home of the Alamo
                  no loss pump
                  The SKS is a suspension pump and is designed to not leak pressure when disconnecting. I have seen it online now for $50-70, though there is a more updated SKS for about half that is smaller (and not quite as cool) with more plastic instead of aluminum and SS.
                  This thread reminded me to check my fork pressure before leaving for rally tonight!
                  Thanks
                  John
                  • g15usmc
                    • Nov 2010
                    • 365
                    • 29 Palms CA
                    Thanks
                    John
                    hey, what about me? I started the thread...LOL JK of course...but here is the pump I got...
                    the nozzle rotates and has a precision release valve on it in order to let very little air out at a time...and the pump is also made of heavy aluminum...Cost: $40.00 they also come with 0-100 and 0-30...I got the 0-60 because I dont know any shocks or even tires for that matter that need 100PSI...
                    Ride Till You Die!
