I picked this up at Harbor Freight for 25 bucks figuring it was worth a try. Had some trouble with it at first until I read some reviews that mentioned having to put a dab of grease on the bleed nipples as it draws air from around it otherwise. After I did that this thing worked flawlessly. After I did the bike I had a brake job to do on a car and again this thing performed perfectly on the rear brakes of the car. On top of coming with the vacuum bleeder it comes with a bottle to put your new brake fluid in with adapters to sit on top of your master cylinder to drip in new fluid so you dont have to keep checking the level. Truly a one man job. A++
