gold valve emulators
  • yamahansolo
    • Aug 2007
    • 1113
    • jawga
    F progressive springs buy gold valves or the mikesxs knockoffs. This thing handles like my 98 yzf600r I s$%& you not!!! The difference is extreme!!! Buy them!!!
    79 xs11 standard
    8mm msd wires
    tkat fork brace...
    Fox shocks...
    mikes650 front fender
    led's gallore...
    renthal bars
    vmax tensioner
    Rifle fairing
  • Cyclechrist
    • 13
    • Bedford MASS
    gold Valves
    where did you by them?
    I have a XS1100 SF 1979 Looking to stiffen up front-end plus add some ability to carry a front fairing
    • tinman905
      • Aug 2007
      • 946
      • Orangeville,Ontario ,Canada
      http://www.mikesxs.net/products-19.html#products
      BDF Special
      • Chuckster
        • 93
        • Crystal Lake, IL
        new springs or emulators or both?
        Since I still have the original springs, I was thinking of upgrading to new progressive springs. After reading your post, should I just keep the original springs and add the gold valve emulators? Or would there be added benefit to new springs and emulators? If I'm upgrading, I would rather upgrade it all at once.
        Chuckster
        '78 XS1100E
        Money can't buy happiness, but it can get you an XS11 and that's a start.
          • 8062
          Chuckster,
          I believe I'm going to make this upgrade myself. It's probably easiest to source the valves from RACETECH. If you buy them from Mike's XS you won't get any support for putting XS650 parts in your XS11. It will save you $100 or so, if you succeed.
          Straight rate springs are required. Have a look a TRAXXION. It seems a reasonable price for exactly what you need.
