I did my inside fuel tank with a POR 15 motorcycle fuel tank kit. There's 3 ingredients - a cleaning solution, a metal curer(super rust killer) and a coating. All non-toxic and the cleaner and curer are water soluble. The whole process is easy and simple with a brilliant end result. The inside coating is a hard silvery grey substance. You can do 2 tanks. Cheap enough too.
Por 15
I just did mine as well. I ordered the Motorcycle fuel tank kit. It worked great but it didn't seem like there was enough product for my Standard tank. I called them and the guy told me to just use simple green or similar to degrease if I felt there wasn't enough Marine Clean in the Kit So I bought a couple of Gallons of Purple Power at AutoZone and Did the 2nd cleaning with that cut 1 to 1. I was also concerned about having enough POR 15 to do the tank and the guy told me that the Motorcycle kit was good for up to a 4 gallon tank. The standard tank is right at 5 gals so I ordered another can of sealer and a quart of metal ready just to be sure I had enough. The Metal Ready is reusable.
Next time I do a tank I'll order enough sealer for the size tank I'm doing use a degreaser for the Auto parts store Wally world or wherever and probably reuse the Metal Ready.Russ Neal
Milton, NH
04 GL1800 ABS
04 Kawasaki Concours(Sold)
99 Royal Star Venture(Sold)
80 XS1000 Special(Sold)
83 XJ750 Midnight Maxim(Sold)
80 XS1100G(Sold)
81 XS 650 Special(Sold)Comment
Hi Russ, I did a 'standard' tank too, to get good use of the sealer you can heat the tank so it's warm inside. The sealer then runs nicely. After coating, I still had a fair bit left over. My kit had a litre of marine clean, so that was plenty. I strained it and kept most of it. It's good stuff for cleaning under the fenders tooComment
