ANybody know how to do this adjustment, it's way friggin' different than on my old xs. I"m almost, I hate to say it, stumped.
fj1100 cam chain tensioner?
A very loud, rattly, YES
To the header pipe rattling. SWMBO's has a problem with #1 header. I brought a stethoscope home from work, and located the offending pipe that way. You can use a long screwdriver the same way. Just touch the tip to the pipe, and your ear to the handle, and you will be able to find the guilty party. I am going to take the pipe to work, and drill a small hole in the back of the pipe and weld it all togeher. That should stop the rattle. I understand that is a common problem on those bikes. I don't know about resetting the adjuster. It has a spring that holds tension against the tensioner rod, and a ratchet assembly that keeps it from moving backwards. According to the book, it has to be removed to retract the tensioner rod back into the assembly You can extend the rod by looseing the bolts that attach the tensioner assembly to the cylinders. That will allow the tensioner rod to extend a little more.
