my 81 400 special has been sitting for a couple of weeks while i waited for a chain puller to come in. put it on last night, went to start it up and got a flood of gas on the ground. it was coming out of the air filter chamber. i discovered i had let it sit on the kick stand with the fuel valve open. i took apart the air filter, drained it, blew air through it to get residue out, and put it all back together. problem is i'm still getting gas out of it, like its backing up from the carb into the air filter.
is it possible its as easy as something clogged? or is there a more serious issue here, like i think? i'm not a mechanic, but if you show me the book or explain the issue, i can usually fix it.
i've only had the bike a few months, there was a lot of rust in the tank and while i THINK i've taken care of it, its still a possibility that rust could be causing clogs somewhere ( i REALLY hope its that easy!)
