Fuel Issue
  • valhallan
    • 66
    • Churchville, Maryland
    Fuel Issue
    my 81 400 special has been sitting for a couple of weeks while i waited for a chain puller to come in. put it on last night, went to start it up and got a flood of gas on the ground. it was coming out of the air filter chamber. i discovered i had let it sit on the kick stand with the fuel valve open. i took apart the air filter, drained it, blew air through it to get residue out, and put it all back together. problem is i'm still getting gas out of it, like its backing up from the carb into the air filter.
    is it possible its as easy as something clogged? or is there a more serious issue here, like i think? i'm not a mechanic, but if you show me the book or explain the issue, i can usually fix it.
    i've only had the bike a few months, there was a lot of rust in the tank and while i THINK i've taken care of it, its still a possibility that rust could be causing clogs somewhere ( i REALLY hope its that easy!)
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    Use the SEARCH button to find numerous threads on the subject.
    Boils down to:
    -petcock letting gas by. XS1100's have vacuum petcocks so they can leak. You said you left it open so I'm guessing it's manual.
    -float valve in carb(s) not sealing allowing fuel to leak past and flood the floatbowl. This overflows into the airbox and/or the crankcase (contaminating the oil). Check your oil for gas in it.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • valhallan
      • 66
      hmmm
      the fuel had an oil quality to it, enough to make me actually have to check it to make sure it was gas. if it is an issue with the float valve, i'm guessing my options are 1) open, clean, re-assemble, pray or 2) rebuild kit, pray or 3) new carbs?
      • xs650mike
        • 1286
        • Lake County, California
        XS400 fuel leak...
        2 things...vacuum petcock not shutting off and float needle valves leaking slightly. Petcock is easy. Mikes XS manual petcock replacement. Part # 20-0019 http://www.mikesxs.com/mikesxs-fuel_...ategory_id=4.1 I've got one on my XS400 and it fixes this problem. Just plug the vacuum barb on the carb holder. Mike sells a blind plug for this. The petcock comes with different barbs which allow it to be used in a variety of configurations. This petcock will fit both XS400 and XS650 Specials but unfortunately won't work on an XS11. The float needle problem may just be intermittant because of crud in the float bowls occasionally getting between the needles and seats. Pull the carbs and clean the float bowls. Helps to install and inline filter too to prevent future occurances.
        Of course you'll need to remember to turn the petcock on before starting the bike and to turn it off when you park. I've got a little note taped to the top of the tank that says, "Turn the gas on stupid!"
        Shiny side up,
        650 Mike
        XS1100SF "Rusty", runs great, 96k miles
        XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
        Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
        • valhallan
          • 66
          YEAH
          i tend to forget to turn the petcock on or off, and the real probel is when i ride to work, my ride is so short, i can actually make it there with the valve off, and just using the gas already in the engine and in the line. problem is when i go to leave work and the system is dry... takes a few tries for the gas to get back to where it needs to be.
          • Parr8hed
            • Aug 2003
            • 444
            • Southern Indiana
            LMAO!! I have done that plenty of times. I have more than once had to leave the petcocks on prime for a min. to fill the bowls and let me start the motor without cranking on the starter for 10 min.
            Travis Miller
            1978 E
            • valhallan
              • 66
              ok, update
              i took apart the carbs tonight, cleaned them completely, although they looked fairly good to start with, and put them back on the bike. opened the petcock, no leak. cranked the bike up, and it ran for maybe 10 seconds, sputtered and died and fuel starts coming out of the air filter again. cleaned out the filter, hoping (but knowing better) that maybe that was gas left over from before, and cranked the bike up again, and again it ran for a few seconds, sputtered and died and the gas again came pouring out the filter. so... i'm thinking the problem is definitly the carbs, and is the a re-build or buy new part issue? i don't know what all a rebuild kit includes, but i don't remember seeing new floats in them.
              • Parr8hed
                • Aug 2003
                • 444
                • Southern Indiana
                sounds like you need to check your float height and/or clean/replace your needle jets. I am having a brain fart, but i think that is what they are called. anyway they are right underneath the floats. take off the floats, take out the jets underneath them and clean/soak/or just replace those. check the screens on them too. put all back together and then ajust your float height and then report back if still having the same problem.
                Travis Miller
                1978 E
                • e.z.nightrider
                  • Apr 2005
                  • 212
                  • Rockford IL
                  First bike I owned that I got to ride ( the first I owned was a 75 Norton Comando With Seven Miles on It, long story, lived at home, mom said no bike, my things moved to back porch outside, you get the picture) was a '79 XS400 Special. It had a vaccumm controled petcock. Check the O-ring on the diaphram (on the back side of the petcock, make sure it's clean, no scratches or tears) and also the float needles.
                  It's an 80 LG My Midnight Ride
                  81 XJ650 MAXIM The Preachers Bike (Gone but not forgotten)
                  82 KZ 305 CSR Training Wheels (now my daughters)
                  82 GS 850 GL SWMBO's (HER RIDE)
                  'He who wanders is not always lost."
                  • valhallan
                    • 66
                    floats
                    when i took the carbs apart to clean, i did pay special attention to the floats. they move freely and the piston like piece attached (is that the float needle?) also moved freely. i'll take a look at the petcock. as it is, i cant use the standard position on the switch (assuming its clogged) and have to run with it in the reserve position.
                    what i don't understand though, is why would only leak like this when it runs, and not when its sitting? i would think that if the gas is just flowing out of the tank because of a problem with the petcock, wouldn't it flow all the time? (i'm an engineer, i have to know WHY it works, not just that it does, sorry)
                    • Parr8hed
                      • Aug 2003
                      • 444
                      • Southern Indiana
                      the float needles on an xs11 are screwed into the actual carb body under the float. I can not speak for the 400, never had one apart. on an 11 you have to take them out with a socket wrench. that is why i supect that you have a problem with it when it is running. also the float level could be letting too much gas into the bowls while it is running. that could also cause the problem. you may ask some of the carb gurus on the "members lounge", I am not sure how many actually read the "other bikes" threads. just post a note to direct them to this thread. TC in paticular is great with carbs as are many others.
                      Travis Miller
                      1978 E
                      • e.z.nightrider
                        • Apr 2005
                        • 212
                        • Rockford IL
                        If it only runs on res. your petcock is dirty or pluged. The reason it only leaks with the bike running is vaccumm from the carbs (there should be vaccumm line from a carb boot to the back side of the petcock) holds the o-ring open which lets fuel flow to the carbs, when it isn't running There is no vaccumm to open the o-ring and a spring holds the o-ring shut so no fuel flows even with the petcock on. If it only leaks while running I would guess that the float hight is wrong, the float needles are dirty and hanging up, worn and needto be replaced, or the float needle seat is dirty.
                        Ed Z.
                        • valhallan
                          • 66
                          thank you
                          for the explanation EZ. i love it when things make sense lol. i think i only have 2 questions left (on this topic anyway) 1) if i have to adjust the float needle to allow in less gas, do i adjust it to extend more, or to extend less? i would assume less, but you just never know for sure, and trial and error is getting real old. my other question is quasi- related, could this issue also cause the engine to race when i'm stoped at a light due to the engine getting to much fuel? when i first got the bike, the engine raced like crazy, like it never came down even when i was sitting still, i cleaned the carbs and the problem eased up a LOT, but has gradually been going back to that same state since then.
                          sigh, another night with my wife complaining my hands smell like gasoline.
                          • Pat Kelly
                            • 3046
                            • Golden Valley, AZ
                            If it is a brass float check that it dosen't have a hole in it. Shake it and listen for gas inside it. If it's the solid plastic-type float then nevermind
                            Pat Kelly
                            • prometheus578
                              XS-XJ Super Guru (RESIGNED)
                              • Aug 2004
                              • 4012
                              • Olympia , Wa.
                              &quot;ChooChoo Charlie was an engineer...&quot; (commercial for GoodNPlenty candy)
                              I'm confused by some of the posts here; whether you have a vacuum petcock or not. Either way, your floats are not shutting off the fuel. With a vacuum petcock, that would answer why it doesn't flood when off, but floods when they get engine vacuum. problem is with the floats or needle and seat.
                              ("But wait... there's more! If you call within the next thirty minues, you will receive free...) As an extra bonus, you may have clogged float bowl vents! Had a Triumph that only leaked when running. Was clogged vents, though the Triumph Tech Line guy couldn't explain to me why. As a junior engineer and general idiot, I figured it out fer meself.
                              Carb vent is to allow air to leave the carb as the float rises, taking up space in the upper chamber of the bowl. If the bowl is not vented, the air above the floats becomes trapped. As the floats rise, this trapped air builds up a slight pressure. This higher atmosphere becomes more dense. The delicate working status of the float's bouyancy changes... the float is no longer able to "float" upward into this denser air, hence, it doesn't reach the apex of it's travel and doesn't fully shut off the fuel flow. Carbs will not leak when off... but will now leak when running.
                              Not bad for someone that doesn't know what he's talking about!
                              Check your carb vents, but also bench test your carbs. Take the bowls off, flip them over, turn on the fuel, and see what happens. Check for holes/fuel in the floats, too. Submerge them, using pliers, into a pan of hot water. the air inside will expand... and if you see bubbles, then you've got holes. Floats with fuel in them, being heavier, obviously will not float properly.
                              Yup... too much fuel... flooding out the sparkplugs.
                              Clean the tank again and install inline fuel filters. You may have a chunk of rust between the float needle and seat preventing it from sealing and shutting off the fuel.
