thanks man that will help with the starting problem
83 yamaha virago 920
i just order the kit and i am going to try to get around to putting it in sometime this winter and then i got to get a new starter silonoid and then maybe we should be ready to get this bike back on the road79 yamaha xs1100f standard
best 1/4 mile 13.282@99.40Comment
well just got the kit put on and the new starter soilnoid and the bike started right up and it runs like new but it is still charging alittle low so what all parts should i look at for the charging system on that bike with it running it is only charging at battery voltage so i still got a problem but it starts alot better then it did79 yamaha xs1100f standard
Check and see if the ALT on the bike uses brushes. If so, try cleaning the armiture they run on, and check to be sure they are NOT worn out.
I would then take a VOM and starting at the ALT wires, check all through the system. It could be the reg/rectifier, but they usually don't break. I would also verify ALL the connections and ground wires!! make sure everything is clean, and no resistance through connectors.
RayRay Matteis
Your not being much help John
You know darn well it would not take 5 gallons of gas
When a 10 isn't enough, get a 11. 80g HardbaggerComment
