Honda CB550 frame
  • Steveolboy
    • Nov 2017
    • 15
    • Panama, NY
    Honda CB550 frame
    OK, got a 75 CB550 "Parts lot" last week. The parts are now a near complete bike with some nice new stuff, clip ons, seat, and 4 into 4 which cost more than the whole pile, and even a title!
    The frame has been cut badly to remove the seat hinge and kickstand leaving thin spots and holes( sawzall??). Are these frames anything other than mild steel? I have no problem welding the holes up but want to use the correct materials and thicknesses.
    81 XS1100 Venturer
    79 XS1100SF
    78 XS650
    77 XS750 triple
    81 ZV750 cafe
    75 CB550 cafe
    74 CB350 Four
    71 enduro 100
    81 CB900C
    79 Cm185T
    Too much other stuff to list!!!
    For your application, a MIG wire feed works fine. If opting to use an arc welder, 3/32" LH 70 with amperage set approx. 70-80 amps. Can also arc weld things up using Lincoln rod 6011 also 3/32" with amperage set at 90amps. This particular rod is used when components being welded are not totally clean. BTW, just some input from a certified welder and fabricator.
    • Steveolboy
      • Nov 2017
      • 15
      • Panama, NY
      Thanks man. I will be using a Hobart Handler 175 most likely. I appreciate your help.
      81 XS1100 Venturer
      79 XS1100SF
      78 XS650
      77 XS750 triple
      81 ZV750 cafe
      75 CB550 cafe
      74 CB350 Four
      71 enduro 100
      81 CB900C
      79 Cm185T
        • 1567
        Good Luck with your project.
        CB550 is a fun bike. Owned one in California and rode it 25,000 miles.
        Mostly in the Sierra Nevada's.
        It never let me down but does have 'interesting' behavior running hard in the mega twisties.
        Post some pics and progress report .................
        • Steveolboy
          • Nov 2017
          • 15
          • Panama, NY
          I will. Bought it in boxes. Had a green 74 CB550, and several 74 750's I sold years ago and regretted the minute they left the drive. No more, I am keeping everything forever now. My wife is not nearly as enthused about that as I am but the garage is where I have the final say...may be the only place but I am clinging to it.
          81 XS1100 Venturer
          79 XS1100SF
          78 XS650
          77 XS750 triple
          81 ZV750 cafe
          75 CB550 cafe
          74 CB350 Four
          71 enduro 100
          81 CB900C
          79 Cm185T
