my 650 charging system troubles
  • Blank Slate
    • Nov 2013
    • 393
    • Ottawa, Ontario, Canada
    Sigh... I've been having issues with this bike regarding the battery and stalling at red lights. So I bought a new regulator from oregonmotorcycle. Got rid of the old fuse box and switched to blades. Bike was running great at first. But I went on a ride and bike died at a red light, battery...
    Any PMA's recommendations from 1100 members?
    Keep in mind I'm in Canada.
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
    • 8074
    Looking into my crystal ball, I see your PMA purchase morphing into you getting rid of the bike for pennies as compared to what you have in it. I don't recommend it.
    Since you have let the smoke out of the wires, that is a sign of too much current. Too much current means resistance is too low. The XS650 rotor is notorious for shorting. That's where you start. Read the resistance between the copper rings on the charging rotor. It should be close to 5 ohms. My bet is that it will read closer to zero. If that's the case, that will explain the dead battery, no charge, and too much current. Send the shorted rotor to Custom Rewind in Alabama. It will be good from now on.
    You need a multimeter. You'll have to learn how to use it. Fix the original system. Permanent Magnet Alternator is not an upgrade. Good luck.
    Lastly, take this issue back to XS650.com. You will get far better help over there. An XS1100 has very little in common with an XS650.
      • 8074
      We got him fixed up over on the 650 forum. Back to your regularly scheduled program.
