1983 Kawasaki KZ 550 LTD woes
    • 3370
    That could be a good bike for you motoman. Weighs 475 pounds drippin wet, comes up easy on the center stand, and you weigh half what I do. It would be a small-size rocket with you on it. :-)
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
      • 2110
      One thing that annoys me with this bike-You need to pull in the clutch to start it-can that be disabled until he can get the bike straightened out?
        Nope, that would be a factory safety switch at clutch housing just like that's on my Venturer oldyam80sg. Howard, upright the weight is not an issue. Even with THAT bike, a tipover setting still with me aboard would likely put me in a wheel chair for my remaining days. Just have really think about it before I decide to throw a leg over and ride the Venturer this Spring.
          • 3370
          Sounds like you are thinking about what you need to be thinking about, Brant.
          For the clutch switch, could it be at the clutch lever itself? Or is that usually only with hydraulic clutches/brakes?
          Good trivia, didn't know the Venturer (or any XS) had a clutch switch.
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
            All 80 and later XS11s had the OEM clutch switch in wiring to left side clutch perch.
              • 2110
              Well I went to this guys apartment today-Hooked up multi-meter and battery voltage no key on was 11.40 volts-turned on key and bike would not start-put on jump pack and bike started-took off jump pack battery voltage was 12.2 volts - Reved up bike 13.4 volts and dropping-took bike for a ride down street and made it back-shut off bike nothing-put on jump pack bike started-took out battery and it is sitting in my garage now charging-only goes to 75% and wont charge any more.Are we looking at a dead cell? Walmart battery maybe 4 months old.
                Might wanna look closer.......IIRC so does your SG.
                  WallyWorld being your key answer. Spend the extra money and use an Interstate battery. You gain nothing using a cheapie battery. I get 7-9yrs. from
                  Interstate batteries, with one recharge from a stupid mistake. The Venturer's Interstate is going on year 7 as of now.
                    • 3370
                    Yeah, that is a possibility for sure with the powersport batteries from big chain stores. It's inconsistent on how long they have been there, and the quality isn't necessarily the best. I am sure you can talk Walmart into giving your money back, even without the receipt they are pretty good with that kind of thing. Get a new battery and the woes will be gone.
                    That's a negative on the clutch switch Ghost Rider.
                    2001 ZRX 1200
                    1982 Seca 750
                    1983 Nighthawk 550
                      • 2110
                      What prevents the battery from charging when it is installed on the bike?
                        • 3370
                        Looks like it is charging based on 13.4 volts? Yeah, dead cell or cells and it can't hold enough charge to start the bike.
                        2001 ZRX 1200
                        1982 Seca 750
                        1983 Nighthawk 550
                          • 2110
                          Yes but as I held the multimeter on the battery voltage steadily dropped.Was less than 12 volts before i rode bike
                            • 3370
                            So, at a steady 3-4k was voltage steady or dropping?
                            2001 ZRX 1200
                            1982 Seca 750
                            1983 Nighthawk 550
                              • 2110
                              dropping I dont understand why besides bad cell
                                • 3370
                                Sorry for all the questions... that voltage was at the battery, right? Can you check it before the battery?
                                2001 ZRX 1200
                                1982 Seca 750
                                1983 Nighthawk 550
