Gasket Swap Between '79 XS1100 and 850?
  • sail4free
    • May 2014
    • 138
    • Boise, Idaho
    My mechanic asks:
    "Do you mind if I scrounge some of the spare parts off of your broken carbs for my 850 carbs? Your carbs racks have what appear to be a much more durable float bowl gasket made out of rubber. Mine were paper and just fell apart."
    The 850 is Yamaha . . . will the float bowl gasket interchange for him? Or do I need to know the year of the 850? Thanks!
    JIM ~ BOISE, ID
    79 SF
    • 3917
    Unless he swapped his Hitachi carbs for Mikuni MKII's, they are not the same float bowl. However, the gasket is similar by appearance, as most are. He is better-off buying gasket material and making his own.
    • sail4free
      • May 2014
      • 138
      • Boise, Idaho
      Thanks!
      I'll let him know.
      79 SF
      • yamtom
        • 275
        • Midland Michigan
        carb parts swap
        I had an old 750 triple parts bike, and I used some bits from the carbs for the 1100 carbs. The 750 carbs used the early eleven carb parts but some later stuff did swap.
        Bikes Now.
        80 MNS 11 pods,georgefix kit,stock jets, HD Sporty muffs
        79 XS 11 Special, Emgo pods, stock jets, with Pacifico fairing, hard bags, intact stock pipes Sold
        83 Yammi Venture with custom footboards, 20k miles.
        83 Yammi Venture parts bike
        99 Valkyrie shield and bags 37k miles like new
        08 ZX 14 Kawa Ninja 6k miles Sold
          • 3917
          Correct. The 750's used Mikuni MKI/MKII carbs. However, the 850's used Hitachi carbs.
